125ASX2 amps for sale
Hope this is not thread highjacking
I am currently selling a couple of 125ASX2 amps which I bought from Ghentxu a couple of years ago.
http://www.diyaudio.com/forums/swap-meet/299975-several-bang-olufsen-icepower-125asx2-2x125w.html
Cheers, Tristan
Cheers, Tristan
125ASX2 Designer's Manual
Hi!
I've just had a note from my friend Mike who's a bass guitarist and has electronics experience like me, and he's buying a Fender Rumble 500 with one of these ICE 125 Modules!
Could someone pm or email me a copy of the 125asx2 Designer's Manual please?
Many thanks,
Chris Williams
Hi!
Many thanks,
Chris Williams
Please send me your email address and I'll send you a copy
Hi!
Many thanks,
Chris Williams
ICEpower ASX Case-Kit 125ASX2
Hello the Case Kit is now with me and will be set up at the week end.
Since I have a few questions about this I will contact you when the time has come.
Thanks in advance
Cardone
Thanks in advance
Cardone
I am very satisfied and can now enjoy the music ...
The amplifier is very good ...
Ciao Cardone
Ciao Cardone
Looks good, I have the exact same module and case ordered. What speakers are you powering with this amp? I am am hoping to run mine off the pre outs of my Denon avr x-4100. Or if that doesnt work I will use my carver c-1 Billd preamp. I am hoping to power Energy RC-70 towers and a center channel. Not sure if I will need to go BTL mode ore the 65watts at 8ohm will be sufficient since all the low end is courtesy of SVS pc-12 pluses.
Hello, only now I read your contribution ...
I use 2x200Watt 4Ohm 3-way loudspeakers from Teufel.
As a preamp I use a HIFI PGA2311 Remote volume control preamplifier Stereo preamp with 4 way inputs or the FX-AUDIO TUBE-03 Préamplificateur Tubes 6J1 Stéréo Noir with GE JAN 5654W Tube.
The sound is really good ....
For me it was a very good decision to buy the components
A few days ago I ordered the 250asx2 ......
I wish you a nice day
Ciao
Ciao
^ I see you're using an Audiophonics branded RaspDAC. What variant of MPD are you using to get the 2-line display to work? PiCore?
Hello,
I use moode audio as MPD.
For display I use pydPiper.
For Power management for Audiophonics I-Saber ES9023 V3.
All info you can find at MoOdeAudio.
Hello,
Thanks. I have the same case, but using Ropieee as the roon end-point. Of course, Ropieee being an image doesn't allow for such customization. So no display and blinking power switch.
Hello redjr,
my devices, cables, housings have arrived ...
In a few days I will assemble everything ....
many Greetings
Cardone
Good luck with your build. I built a similar class D amp out of ICEPower modules a few years back. (125ASX I believe.) Very nice sounding with lots of 'detailed presence'.Hello redjr,
many Greetings
Cardone
Edit: Correction, 250xxx modules.
Finally finished....
Hope I did everything right ..
Well, if there was no magic smoke you probably did okay! 😀 Success? HaveFinally finished....
had a chance to listen to it yet? Impressions?
everything went well....
no smoke was to be seen ....
Long live the music ......
Ciao
Ciao
Congrats for your build
Which amp is it ? You have pics a few post back of another build using the 125asx2. This one has a different pcb layout and heatsink.
BR
Eric
- Vendor's Bazaar
- FS: ICEPower 125ASX2 module
