FS: ICEPower 125ASX2 module
125ASX2 Designer's Manual
Hi!
I've just had a note from my friend Mike who's a bass guitarist and has electronics experience like me, and he's buying a Fender Rumble 500 with one of these ICE 125 Modules!
Could someone pm or email me a copy of the 125asx2 Designer's Manual please?
Many thanks,
Chris Williams
Amplifier icepower 125ASX2
Amplifier arrived today.
Wait for the kit housing to build it up ...
A few photos ..
ICEpower ASX Case-Kit 125ASX2
Hello the Case Kit is now with me and will be set up at the week end.
Since I have a few questions about this I will contact you when the time has come.
Thanks in advance
Cardone
I am very satisfied and can now enjoy the music ...
The amplifier is very good ...
Ciao Cardone
Looks good, I have the exact same module and case ordered. What speakers are you powering with this amp? I am am hoping to run mine off the pre outs of my Denon avr x-4100. Or if that doesnt work I will use my carver c-1 Billd preamp. I am hoping to power Energy RC-70 towers and a center channel. Not sure if I will need to go BTL mode ore the 65watts at 8ohm will be sufficient since all the low end is courtesy of SVS pc-12 pluses.
Hello, only now I read your contribution ...
I use 2x200Watt 4Ohm 3-way loudspeakers from Teufel.
As a preamp I use a HIFI PGA2311 Remote volume control preamplifier Stereo preamp with 4 way inputs or the FX-AUDIO TUBE-03 Préamplificateur Tubes 6J1 Stéréo Noir with GE JAN 5654W Tube.
The sound is really good ....
For me it was a very good decision to buy the components :) :)
A few days ago I ordered the 250asx2 ......
I wish you a nice day
Ciao
Ciao
Thanks. I have the same case, but using Ropieee as the roon end-point. Of course, Ropieee being an image doesn't allow for such customization. So no display and blinking power switch. :)
Hello redjr,
my devices, cables, housings have arrived ...
In a few days I will assemble everything ....
many Greetings
Cardone
Hello redjr,
many Greetings
Cardone
Good luck with your build. I built a similar class D amp out of ICEPower modules a few years back. (125ASX I believe.) Very nice sounding with lots of 'detailed presence'.
Edit: Correction, 250xxx modules.
Finally finished....
Hope I did everything right .. :) :)
