GB for ArDAM Lite bare PCBs
OK, I'll need to properly debug this code when I get my Soekris back.. coding blind is not a good idea..
Regarding signal type display, are you absolutely sure that your source is indeed outputting DSD? A good test would be to play some 44.1K material, then play some DSD and see if the screen displays a different sample rate & signal type.
Not showing the resolution while shifting to another piece of music with the same resolution is normal - the code depends on the DAM reporting a new sample rate so if that does not happen (like when the dam does not lose lock due to an interruption of the i2s stream or a change in the sampling rate) the code has no way of knowing that something has happened.
The start-up volume thing is easy to fix. Just insert this:
Code:
Serial.print("V-");       // output the new volume level to the DAC's serial port
Serial.println(Vol);      // output the new volume level to the DAC's serial port
after the poweron = true; statement at the setup().
I think you are doing well coding blindly :)
Thank you, I will implement that for volume.
Yes, that is what I did. When it shifts to other resolutions, it shows the sample rate ( e.g. from 44 to 88 or 96), but not for DSD material. And I had an easy way to test what I got, since using Roon I could see what was sent ( 384). Furthermore, when I shifted to another source it temporarily showed the high resolution. But that is definitely a minor detail :)
I corrected to this - otherwise I got an error in compiling
Serial.print("Vol"); // output the new volume level to the DAC's serial port
However it is still giving full volume until I touch the volume on the remote. Just for your info - it is not critical :)
That's weird - something got left out in my copy - paste. The correct lines are these:
Code:
This should take care of the full volume issue..
Crap, the platform seems to be messing it up.
It should look like this:
attachment.php
My son came home and he showed his skills at arduino programming. As mentioned, I have a USB2I2S and a Raspberry that I can use as input for the Soekris. An Otto is used for that, via a physical contact. We took the signal pin from the Otto and asked the nano to display PC/ PI beside the volume.
The volume is still not adjusted, even with the new code, and we have not figured out why?
Joined 2004
ArDAM Lite controlled DAM1941
Hi folks,
I -almost- finished my ArDAM Lite controlled DAM1941.
It's now in "breadboarded" state, but sooner or later I will make a case.
I attached my configuration's block diagram.
The ArDAM Lite PSUs is DiyInHK dual LT3042 (+transistor) versions (+5V, +3V3).
My OLED is 1.3" SH1106 chip version (I2C).
I rewrite Dimdim's code.
Because Arduino Nano has very narrow space for program, only the "necessary" commands and status informations have been implemented:
Commands:
- Volume up; Volume down;
- Source selection: Auto, USB, AES/EBU, BNC SPDIF, RCA SPDIF, Opical (Soren now not implemented I2S);
- Filter changing: four filter selection.
Status display:
- Volume;
- Type of stream (PCM, DSD);
- Sample rate;
- Source;
- Filter.
Because Nano's space is "full", the "draw_logo" procedure now is commented.
The IR codes is my remote control's code, must be change your remote codes.
Use attached Dimdim's "IR_Scanner" for detecting codes from your IR remote control.
If you want to see DAM's serial commands, use attached "serial_console" program.
Have fun and enjoy yourself!
  • ArDAM_Lite_1.30_OLED_Jolida_remote_V_1.3.zip
  • ArDAM_Lite_IR_Scanner_1.30_OLED.zip
  • DAM1941_serial_console.zip
Joined 2004
Can I buy this?
Each component purchasable from the net, ArDAM Lite PCB there from Dimdim, 1.3" OLED, Arduino Nano, parts from ebay.
I use this PSU -because I own several pieces- for control and display:
DiyInHK dual PSU from 0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A*x2 - DIYINHK.
My breadboarded system use LT3045 PSUs for DAM, but any good PSU (for example UBiB) usable.
I bought two bobbin transformers for PSUs (INDEL 40VA 7.5V or 9V AC, depends of PSU type). Any transformer usable which have low primary-secondary capacitance. For me toroid not this type.
Thanks for details.
nash
