200W MOSFET CFA amp
Now are 10 boards on the list. If 40 EUR plus shipping per board is OK for you I will order the boards production?
tjencks 6 pcs 200W amp boards
vitalica 2 pcs 200W amp boards
malibutwins 2 pcs 200W amp boards
This is the last list, only 6 boards confirmed. Minimum order pcs is 10.
………………………………………………………………..confirmed
tjencks 6 pcs 200W amp boards...………..?
vitalica 2 pcs 200W amp boards …………..OK
malibutwins 2 pcs 200W amp boards.....OK
arthur 2pcs 200 amp boards...……………...OK
It looks tjencks does not confirm his order, 6 pcs in total is not enough to set the pcb production.
I'm happy about the price. How can i send the money?
:D
I have to order the boards and when I received the boars I will send ebay money request.
Only problem is that I need 10 board minimum to be confirmed before I order production, but still it's only 8.
arthur 2pcs 200W amp boards...……………...OK
zsaudio 2pcs 200W amp boards...………...OK
Hello,
I not reading this thread to much pages
how about protection about this amp ?
Short circuit
Overloading
Clip
DC like triac crowbar if device fails ?
any amp > 30V Rail should have DC protect to protect speaker from amplifier device fails
This is important, because this amp running with high rails
I lost my speaker long time ago after an amplifier fails and DC OUT full rail kill very quick my HI-FI speaker before relay can disconect
never lost any speaker again after add this circuit
Hello,
Short circuit
Overloading
Clip
If the amp use this PS regulator has all needed protection.
https://www.diyaudio.com/forums/solid-state/243481-200w-mosfet-cfa-amp-108.html#post4951771
Dear Dadod,
May i ask for the ltspice file of your last version? Sorry if it's already been here i'd like to simulate it while assembling. I'd like to order the parts and just would like to know the components size too.
Thank you.
You did not answer my question, do you confirm to buy 6 pcb boards?
BOM attached.
PCB photo view attached.
  • 200W-CFA-VMOSFET-BOM-1.3.2-balanced ready.txt
Code:
Originally Posted by tjencks
I'm good with the price.
What is cost for the PS regulator ?
So I can confirm you for 6 pcs of 200W pcbs?
The PS regulator PCS should be about 20 EUR plus shipping. I need few days to recheck the PS regulator layout.
Dear Dadod,
I'm confused. Did not you point it to tjencks?
I'm interested in 2 pieces of 200W pcbs (4 pieces if we are not enough for the order (you said 10 boards at least)).
I'm interested in 2 pieces of PS regulator board too.:)
thank you
