CRC Power Supply (Class A amplifier)
Joined 2018
Hello Hicoco,
If you use higher values in a 250W power amp, the power dissipation and voltage drop across R2, will increase tremendously. Following text gives the example.
R2,ohm..... Power,W ..... Del V R2
0.1 ..... 6.1 ..... 0.8
0.15 ..... 9.1 ..... 1.2
0.22 ..... 13.3 ..... 1.7
0.33 ..... 20.0 ..... 2.6
0.47 ..... 28.4 ..... 3.7
Thank Prasi, the second value is amp (I) right ??
so if i understand right and i have under 6.1 amps i will not need resistor
reading your question again, here is the answer.
if you have lower current demand from amp, then you can go for higher value of R2 and thus achieve lower psu ripple.
CRC configuration helps you to minimize psu ripple at the cost of loss of headroom and practically managing dissipation in R2 itself.
While lower ripple is desirable, it then becomes a question of managing dissipation in R2 and PSU voltage drop caused by R2.
I hope I have made things slightly clear.
regards
Prasi
Joined 2018
regards
Prasi
:up::up::up:YES Merci
sthcoaster-2 nos. paid, shipped
MartinJaeger- 2 nos. paid, shipped
Amadeus00- 2 nos. paid, delivered
theoracle- 4 nos., paid, shipped
Hicoco- 2 nos, paid, delivered
Oracle1-2 nos. paid, delivered
Mituisho - 2 nos. booked, paid, to be shipped with 2 nos.baby huey's
Mravinsky - 4nos to be shipped with 4 nos. baby huey's
TS Lo - 2nos to be shipped with 2 nos. baby huey's
14 remaining
Thank you very much guys for confirmation of delivery.
theoracle- 4 nos., paid, delivered
Mobes123- 6 nos. PM sent.
8 remaining
Thank you theoracle for confirmation.
Prasi
sthcoaster-2 nos. paid, delivered
Mituisho - 2 nos. booked, paid, shipped
14 remaining
Prasi
MartinJaeger please confirm the delivery
Hello Hicoco,
MUR860G is an ultrafast recovery diode. So if you are not using the CS, RS, C2 snubber, then use C3,C4,C5,C6.
On the other hand, if you had used MSR860G, which is a soft recovery diode, then there is no need to use C3, C4, C5, C6.
please refer the schematic.
regards
Prasi
I would like to purchase two boards.
A couple of years ago I purchased 4 United Chemicon EKMH350VQT563MB80T on a whim.
Despite whatever Mouser's website says, they have 5 leads and I can't find the specs in the data sheet (35V models stop at 22,000uf on the data sheet)- but am holding one in my hand - they do exist.
Spec's listed on the Mouser website are
56,000uf
35V
ESR 8 mOhms
Ripple Current 8.29 A
40mmx80mm
If you have any suggestions for building with these (or reason to NOT build with them:confused:).
Maybe something more robust than a CL-60 for mitigating power on thump.
If that's obscene for the capacitance, maybe dual mono PSU's with two transformers? When building dual mono would one half the transformer size - instead of a single 400VA, 2x 200VA?
Not sure what amp I'm going to build next, probably an M2, or F6,
