Simple High Performance DC Coupled Class A HPA with sub PPM THD
Founder of XSA-Labs
Joined 2012
The ultralow noise adjustable voltage regulators from eBay arrived. Need to find out pin designations. Looks like the positive is red and negative regulator is green.
attachment.php
Founder of XSA-Labs
Joined 2012
Verification build completed
I finally had a good day to work on this amp. The build went together well. It's a big project with all the little sub boards. There is an error on the volume pot board - one of the pads on the smaller right channel is not connected to anything - jumper it to the right input. The crossfeed filter has some errors - I managed to fix it partially so that it works but the defeat feature does not fully defeat it. Sounds great. Bias is 116mA with +/-17.5v under load. DC offset is -2mV and 6mV.
Completed amp before buttoning up:
attachment.php
Closeup:
attachment.php
Closeup of ebay voltage regulator (negative one):
attachment.php
Closeup of outputs and heatsink mounting:
attachment.php
Closeup of Xfeed:
attachment.php
Closeup of vol pot board and headphone jack board:
attachment.php
Amp with headphones and Cayin N3 playing:
attachment.php
Underside panel showing all the screw holes used to mount parts on the other side:
attachment.php
Founder of XSA-Labs
Joined 2012
Some Measurements
It's a pretty clean amp. I am using my Cayin N3 with 1kHz test tone. The N3 and Focusrite sort of limit the harmonic distortion measurements as the self THD of the DAC is about 0.003% at -1dB FS. I am keeping it in the -10dB to -20dB region.
Here are some FFT's driving a 51ohm 1W metal thin film dummy load resistor.
1.03Vpp into 51ohms:
attachment.php
2.76Vpp into 51ohms:
attachment.php
14.0Vpp into 51ohms:
attachment.php
One thing to note is how quiet the power supply is for being a wall plug supply. There is essentially no mains or its harmonics - quiet like a battery.
There is absolutely no audible noise/hiss/hum with the source turned off and the volume turned all the way up with my OB-1's which are 55ohms and 96dB. Normal listening voltage levels with OB-1's are about 100mVrms, so you can get an idea that the data in the plots are for ear blistering levels, or for very insensitive phones.
Founder of XSA-Labs
Joined 2012
Thanks, Hugh. It sounds very neutral and very revealing with no caps in signal path. The amp has plenty of headroom for crescendos and will make my headphones recoil on bass kick drum. The casework was a royal pain as you can imagine. Took me better part of a day to assemble. I’m happy with the measured performance and how it sounds. The DC-DC PSU with low noise regulator works very well. It can drive power hungry planar magnetic cans quite admirably. I am using Fairchild TO220 FQP MOSFETs for first time - they sound great.
