Unexpected syntax error from LTspice with 3rd party lib
I tried to use the ST's diac library in LTspice, but I got this somewhat bizarre error message:
attachment.php
The sim ran OK, but the message popped up afterwards, and I imagine the sim didn't take into account the correcting coefficient of 0.342 pertaining to the DB3 diac (or is it the 1.462 factor, anyway there must be something slightly wrong somewhere)
attachment.php
I am no expert in spice syntax, but the operation in the line in question looks like a legit and ordinary multiplication using the asterisk symbol: 1.462*{Tr}, which should pose no problem, except that in the error message, the asterisk shows as a star.
Could it be an unicode or ASCII interpretation problem?
I intended to append the ST lib, in case, but I forgot or mismanaged something.
Here it is, in its full splendor, in case someone is interested:
Edit: somehow, it doesn't work, meaning the forum doesn't work properly, and I made no error in the first place.
Here is the text version, which should go through and be perfectly equivalent:
Code:
*  File     : diacs.lib
*  Revision : 8.1
*  Date     : 27/01/2017
* Please Read Carefully:
*Information in this document is provided solely in connection with ST products. STMicroelectronics NV and its subsidiaries (“ST”) reserve the
*right to make changes, corrections, modifications or improvements, to this document, and the products and services described herein at any
*time, without notice.
*All ST products are sold pursuant to ST’s terms and conditions of sale.
*Purchasers are solely responsible for the choice, selection and use of the ST products and services described herein, and ST assumes no
*liability whatsoever relating to the choice, selection or use of the ST products and services described herein.
*No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted under this document. If any part of this
*document refers to any third party products or services it shall not be deemed a license grant by ST for the use of such third party products
*or services, or any intellectual property contained therein or considered as a warranty covering the use in any manner whatsoever of such
*third party products or services or any intellectual property contained therein.
*UNLESS OTHERWISE SET FORTH IN ST’S TERMS AND CONDITIONS OF SALE ST DISCLAIMS ANY EXPRESS OR IMPLIED
*WARRANTY WITH RESPECT TO THE USE AND/OR SALE OF ST PRODUCTS INCLUDING WITHOUT LIMITATION IMPLIED
*WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS
*OF ANY JURISDICTION), OR INFRINGEMENT OF ANY PATENT, COPYRIGHT OR OTHER INTELLECTUAL PROPERTY RIGHT.
*UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED ST REPRESENTATIVE, ST PRODUCTS ARE NOT
*RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING
*APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY,
*DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. ST PRODUCTS WHICH ARE NOT SPECIFIED AS "AUTOMOTIVE
*GRADE" MAY ONLY BE USED IN AUTOMOTIVE APPLICATIONS AT USER’S OWN RISK.
*Resale of ST products with provisions different from the statements and/or technical features set forth in this document shall immediately void
*any warranty granted by ST for the ST product or service described herein and shall not create or extend in any manner whatsoever, any
*liability of ST.
*ST and the ST logo are trademarks or registered trademarks of ST in various countries.
*Information in this document supersedes and replaces all information previously supplied.
*The ST logo is a registered trademark of STMicroelectronics. All other names are the property of their respective owners.
*© 2008 STMicroelectronics - All rights reserved
*STMicroelectronics group of companies
*Australia - Belgium - Brazil - Canada - China - Czech Republic - Finland - France - Germany - Hong Kong - India - Israel - Italy - Japan -
*Malaysia - Malta - Morocco - Singapore - Spain - Sweden - Switzerland - United Kingdom - United States of America
*[url=http://www.st.com]Home - STMicroelectronics[/url]
* 				DIAC PSpice Models                    *
* This DIAC model simulates:
*Tr:      Rise time (in µs)
*Vbo:	  Break over voltage
*Delta_V: Dynamic breakover voltage
*Ibo:     Breakover current
*All these parameters are constant, and don't vary neither
*with temperature nor other parameters.
.SUBCKT DIAC DIAC_IN DIAC_OUT PARAMS:
+Tr=0.342
+Vbo=13.6V
+Delta_V=19V
+Ibo=15uA
* Power circuit *
*Switch circuit*
S_S1         N01041 N01060 N02098 DIAC_OUT _S1
D_D1         N06161 N01041 DZ19V
D_D2         N06161 N01060 DZ19V
D_D3         N10655 N01060 DZ14V
D_D4         N10655 DIAC_OUT DZ14V
V_IDIAC1     DIAC_IN N01041 DC 0Vdc AC 0Vac
C_C1         N02098 DIAC_OUT 1u IC=0
R_R1         N02098 TRG  1.462*{Tr}
RS_S1        N02098 DIAC_OUT 1G
E_ABM1       TRG DIAC_OUT VALUE { IF(ABS(I(V_IDIAC1))>{Ibo},1,0)}
C_C2         DIAC_IN DIAC_OUT 10p
* Switch Model *
.MODEL        _S1 VSWITCH Roff=1e7 Ron=2.2 Voff=0.1V Von=0.99V
* Diodes Model *
.model DZ14V  	D(Is=3.142f Rs=0.1 Ikf=0 N=1 Xti=3 Eg=1.11 M=.3282
+		Vj=.75 Fc=.5 Isr=1.973n Nr=2 Bv={Vbo} Ibv=.14467 Nbv=1.093
+		Ibvl=.1m Nbvl=1.2722 Tbv1=001433.3u)
.model DZ19V D(Is=6.994f Rs=5.612 Ikf=0 N=1 Eg=1.11 M=.2906
+	     Vj=.75 Fc=.5 Isr=2.088n Nr=2 Bv={Delta_V} Ibv=.17098 Nbv=1.2072
+	     Ibvl=2.002m Nbvl=1.1457 Tbv1=888.89u)
*	Vz = 18 @ 14mA, Zz = 37 @ 1mA, Zz = 11 @ 5mA, Zz = 7.9 @ 20mA
.ends
* 				Standard DIACs definition			    *
.subckt DB3G1 A K G
X1 DIAC_IN DIAC_OUT DIAC params:
+Tr=0.342
+Vbo=10V
+Delta_V=22V
+Ibo=10uA
* 2017 / ST / Rev 0
.ends
.subckt DB3TG DIAC_IN DIAC_OUT
+Tr=0.342
+Vbo=13.6V
+Delta_V=19V
+Ibo=6uA
* 2008 / ST / Rev 1
.ends
.subckt DB3 DIAC_IN DIAC_OUT
+Tr=0.342
+Vbo=13.6V
+Delta_V=19V
+Ibo=10uA
* 2008 / ST / Rev 0
.ends
.subckt DB4 DIAC_IN DIAC_OUT
+Tr=0.342
+Vbo=21.6V
+Delta_V=19V
+Ibo=10uA
* 2008 / ST / Rev 1
.ends
.subckt SMDB3 DIAC_IN DIAC_OUT
+Tr=0.102
+Vbo=13.6V
+Delta_V=19V
+Ibo=4uA
* 2008 / ST / Rev 0
.ends
.subckt TMMDB3TG DIAC_IN DIAC_OUT
+Tr=0.342
+Vbo=13.6V
+Delta_V=19V
+Ibo=6uA
* 2010 / ST / Rev 0
.ends
.subckt TMMDB3 DIAC_IN DIAC_OUT
+Tr=0.342
+Vbo=13.6V
+Delta_V=19V
+Ibo=10uA
* 2010 / ST / Rev 0
.ends
