Heat problem almost solved.
Now fiddling with the relay to get mute pin working proper.
Here's some plots from picoscope: one is the 7k square wave from dac board. another is the same wave after output board.
Here are my measured 7K
File -3db 7K created Audition.
Playback via AsioProxy in DSD256.
Chinese transformer 10K:10K????????? ???????? ???????-???
Correction: here's 7k square wave with 10k load.Here are my measured 7K
LL1527XL transformer. 3.3K R65
Filter for oversampling?
Is this with a minimum phase or partial minimum phase filter?
HQPlayer poly-sinc, DSD5v2 256+fs, DSD256.Is this with a minimum phase or partial minimum phase filter?
Ki-CAD file:
GitHub - lkong/dsc2-header: u.fl dsc2 header with isolator
OSHPark:
OSH Park ~
Promised header with isolator
OSHPark:
OSH Park ~
Ki-CAD file:
OSHPark:
OSH Park ~
I using ISO7640 as suggest of Amanero to isolator too. Do you need to reclock after the Isolator?
I'm not using the isolator for i2s signals.I using ISO7640 as suggest of Amanero to isolator too. Do you need to reclock after the Isolator?
There are for DSD_ON and MUTE.
On the following link:
AK4137 I2S/DSD Sample Rate Conversion Board Supports PCM/DSD Interconversion DOP | eBay
A "new" AK4137 board is offered for 34 usd.
Instead of the other board (having Amanero input) this seems to have I2S input.
I understood that AK4137 doesn't allow top quality conversion, but do You think this board can be of some value for DSC2 ? For example odroid (or RPi3) to DSD through i2s without usb?
What's about "pops" at the starting session or between songs?
This can be a simple and cheap system to start listening...
Fab
Fab
Thanks!
For your work on this. I will certainly be trying it when i get the time! Are you experiencing quiet switching and starting stopping of playback etc, with no annoying pops, etc?
Ki-CAD file:
OSHPark:
OSH Park ~
No pops or clicks.For your work on this. I will certainly be trying it when i get the time! Are you experiencing quiet switching and starting stopping of playback etc, with no annoying pops, etc?
DAC performs perfectly with very engaging and textured sound.
I especially like the vocal and bass from it.
I am building a PC for HQ player to feed the DSC V2.5.2. Currently looking at motherboards. Do you guys use dual NIC (dual lan port) motherboards to connect your PC at the same time to to the NAA (beagle bone black or RPI's) and your network? Or do you just use single NIC and your network switch to connect to the NAA?
Any advice on important AM4 motherboards specifications or what to take into account?
How about an Asus RoG Strix X470-F Gaming mobo or MSI B450 Gaming Pro Carbon AC?
Asus RoG is a very good option for audio. The technology of Digi+ power supply converters is a real find for computer audio.How about an Asus RoG Strix X470-F Gaming mobo or MSI B450 Gaming Pro Carbon AC?
@ppy: hats off to you! That was it.
Perhaps I'lll look into replacing the inverters. Especially if it would work with the rest of the DACs I have.
The good news: I realized that BBB Botic driver has the option to invert the phase. So I connected my BBB->Hermes->Cronus -> BCK.DSDL/DSDR ->DSC2.6 and pin 10 to pin7 to provide DSDEN. Same noise as before.
Then I changed
contents from the default 16385 to 17409.Code:/sys/module/snd_soc_botic/parameters/dai_format
Boom! Perfect sound. There are of course pops from the DSD start as the mute is not operational, but I'll deal with this later - for now I'm quite happy.
Thank you Pavel for your help and continuing support!
Can you post some pictures of your Beaglebone, Hermes, Cronus and DSC2 setup? I plan to do the same thing and I want to make sure that I have everything hooked up correctly.
Thank You
As Pavel announced a new version of DSC2 with onboard reclocker (coming soon),
http://www.diyaudio.com/forums/grou...b-dsd-dac-signalyst-dscv2-38.html#post5525942
new image of Debian with Botic driver is available for testing.
Some more detais:
http://www.diyaudio.com/forums/grou...b-dsd-dac-signalyst-dscv2-40.html#post5532228
Some more detais:
Linux from scratch, not Debian. Sorry for inaccuracy.new image of Debian with Botic driver is available for testing.
Some more detais:
This is not an image - any hints on how to install this? Just copy on an SD card?
Thanks!
Yes, it's very easy to go. Nothing special.This is not an image - any hints on how to install this? Just copy on an SD card?
Thanks!
Configuring:
1. Network setting can be found in /naa/naa.conf
2. uEnv.txt contains optargs= line for configuring Botic driver (I use exactly this line). Just replace by needed. Full descriprion can be found at http://bbb.ieero.com/
How to start:
1. Format active partition of mSD to FAT32.
2. Copy all files from zip to this partition.
3. Edit network settings and uEnv.txt
4. Boot from mSD.
All info can be found in /README.txt
Cap values
Mcluxun,
I ordered a copy of your board, thanks a lot for the design!
What value are the two caps?
Ki-CAD file:
OSHPark:
OSH Park ~
Mcluxun,
Mcluxun,
Here's the BOM I've used:
80-C1206X104J3JAUTO x2
595-ISO7320CQDRQ1 x1
872-920-0133-01 x1
712-CONUFL001-SMD x3
523-A-1PA-137-070B2 x3 (choose length to fit your setup)
Also you will need a 3.3v supply (clean if you will) from DSC side.
- Digital Line Level
- Signalyst DSC1
