GB2 UPDATE
Ajit - 2 PCBS
steefdebruijn - 2 PCBS
amitskamal - 1 STEREO KIT
Neurotica - 2 PCBs
vvs07 - 4 PCBs
outtek - 2 PCB + 4 MOSFETS
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
- Shaan best to check if this is correct, but I noticed Bilal requested the boards in post #336
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
GB2 UPDATE
GB2 UPDATE
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
J.M.K - 4 PCBS + 2 pairs of Mosfets
GB2 UPDATE
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
GB2 UPDATE
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
CitizenKane - 4 PCBs
gaborbela - 2 PCBs
I will start sending PM and invoices to GB members from this Monday.
Thanks for your interest in PeeCeeBee.
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
gaborbela - 2 PCBs
Hi Craydive.
While matching is almost always a good thing, I don't think there will be much improvement over non-matched mosfets in cases other than offset stability, and even that is not guaranteed. If you plan to not use the 4 source resistors then matched pairs may be marginally better for current sharing. Overall, there isn't a big enough reason to recommend matched mosfets for v4h.
Matched transistors deal Q1 Q2 Q9 Q10
As I don't own good tools to pair these,
I'm looking for one of you to do it for me this way:
I purchase a bunch of q1 q2 q9 q10, have them
sent directly to you, you make the necessary pairs for 4 boards, and you keep all left for you.
If you have the tools and interested for this, just PM me.
Maybe more people interested?
Hope this will succeed
Cheers
Jmk
Cheers
Jmk
Cheers
Jmk
I just checked at Farnell. They have them all.
Q1 q2 are quite cheap: 13 euros for 100 of each
Q9 q10 are more expensive: 34 euros for 100 of each.
Jmk
Suggestion: Invest in one of these and you'll be able to do basic hfe-matching of BJTs yourself (plus a load of other stuff) - well worth it in the long run
Loads of other options on eBay and other places as well, but the Peak DCA is a great tool.
Thanks. But is this device precise enough to have a good pairing ?
What other options would you suggest?
Jmk
OK, I just found Shaan's reply on this very question
http://www.diyaudio.com/forums/group-buys/307077-peeceebee-v4-gb-37.html#post5168017
Matching is not really that important here, but try to avoid a hFE difference of more than 25 between PNP and NPN.
No need to such accuracy .............
JMK
JMK
The DCA55 (and it's bigger brother, the DCA75) is plenty accurate for that. I mainly use it for small-signal stuff because the test current is very low. For higher-power transistors I use a DY294 (search eBay) because it's got a couple of steps for Ib. Again, plenty of options available, just have a look around - the point was just that a component tester is a good investment
However, one major benefit for me of the DC55 is that you clip testleads onto the transistor legs instead of putting parts in a socket. That means I can buy taped TO-92 parts and measure them while on the tape. Then I can measure 100 parts at a time (boring) and then just cut off matching pairs when I need them
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
gaborbela - 2 PCBs
Kheon - 2 PCB's
NishantS - 1 PCB
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
gaborbela - 2 PCBs
Kheon - 2 PCB's
NishantS - 1 PCB
I wanted to add 1PCB in PSU, by mistake added here.
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
gaborbela - 2 PCBs
Kheon - 2 PCB's
Ajit - 2 PCBS
Neurotica - 2 PCBs
vvs07 - 4 PCBs
smouse - 2 PCBS
ejno - 2 PCBS
craydive - 4 PCBS
PinkPink - 4 PCBs
Avesbilal - 4 PCB's
hallcon83 - 4 PCB's
gaborbela - 2 PCBs
Kheon - 2 PCB's
GB2 Update:
Ajit - 2 STEREO MODULES - INVOICE SENT
steefdebruijn - 2 PCBS - INVOICE SENT
amitskamal - 1 STEREO KIT - INVOICE SENT
Neurotica - 2 PCBs - INVOICE SENT
vvs07 - 4 PCBs - INVOICE SENT
outtek - 2 PCB + 4 MOSFETS - INVOICE SENT
smouse - 2 PCBS - PM SENT
ejno - 2 PCBS - PM SENT
craydive - 4 PCBS - INVOICE SENT
PinkPink - 4 PCBs - PM SENT
Avesbilal - 4 PCBs - INVOICE SENT
hallcon83 - 4 PCBs - PM SENT
J.M.K - 4 PCBS + 2 PAIR MOSFETS - INVOICE SENT
CitizenKane - 4 PCBs - PAID
gaborbela - 2 PCBs - INVOICE SENT
Kheon - 2 PCB's - INVOICE SENT
The Prof - 1 STEREO KIT - INVOICE SENT
Alright we are moving forward with GB2 for V4H. Anyone wishing for a couple boards or more feel free to join in the fun.
If there is a mistake in the list please let me know.
Thanks.
shaan
Thanks.
shaan
- Group Buys
- PeeCeeBee V4H GB
