P3 Adjustment for the average Hobbyist
Joined 2003
:scratch2: It might be interesting to start a H2/H3 spreadsheet.
Two sets of post adjustment values.
1. H2 H3 adjusted to a pre determined ratios and phase. note the dc offset voltage at the junction of R3 & R4.
2. P3 adjusted to personal taste, note H2 H3 values, that would be interesting in it's self.
In all cases, note the idss; if there is enough data, patterns may emerge.
Sounds good, I know nothing about spread sheets.
Russellc
Just another Moderator
Joined 2003
Yes the 2i2 is a proper sound card which is connected via USB. But performs the same basic functions as a PCI or pcie sound card. The main advantage of going with USB is that it is portable and can be used with a laptop.
There are some things I prefer about using a pci card (I find the gain knobs on the 2i2 really finicky to adjust), but the portability and being able to use a laptop running off battery are the main reasons I went with a 2i2.
edit: the main advantage of using a laptop (apart from portability) is that you can completely eliminate the PC as a source of ground loops.
Tony.
Joined 2003
Tony.
Thanks, I am beginning to understand more and more about this setup!
Russellc
I had my first play with 2i2 and ARTA software. A loop back test with a 1k sine. Fs = 48k and FFT = 131072. It looks very clean. No 2nd and 3rd harmonic which of course is good for a test sine generator. But it looks a little to good to be true?
If I turn up the signal so the green ring goes red......then I got a lot of distortion…..as expected.
What is a good value for FFT?
The number is the resolution? …..higher number better?
The recording takes longer if FFT is high.....which probably is logic.
There is a steep learning curve……...….
Hmm to me it looks like your noise floor is quite high at -80'ish. Maybe lower preamp gain and turn up your output dial. Did you use smoothing? Here is a loopback from my Mbox3 for comparison. Master volume all the way up (as i think Wintermute mentioned) and preamp around 10-11 o'clock.
attachment.php
That's the lowest distortion i could get. Using balanced cables made no difference, and disconnecting the sleeve from the jack (or corresponding pin on XLR) actually gave me increased distortion.
You should be able to go lower for FFT length, 16 or 8k. I don't think it is a critical parameter, just makes measurements faster (with lower values).
Ok.....I tried again by setting the sine generator to -6 dB and set monitor to max. and then input gain to approx. 11 o'clock. But what did the real trick was to change Wnd from Uniform to Hanning. Avg set to linear. I have 0 dB at top and noise floor is now close to -130 dB. Now it looks more realistic with some 2nd and 3rd harmonic. One should think that output of sine generator will give best result if set to 0 dB for max. resolution in the DAC?
Will play more with that…….
By playing a bit with the settings in the loop back test I was able to get the noise floor just under -140 dB and 3rd harmonic which is the most dominant below -100 dB. All other harmonics are well below -100 dB. Is this considered a quality sine that can be used for testing preamps? ….would I be able to adjust P3 using such a setup? ….it will require that the distorsion of the test generator is much lower than the distortion pattern of the BA3 pre?
