LX-mini Crossover Article
Thanks Mr Pass for superb article!
******* Bravo Patron *******
Yummy delicious DIY :yummy: :D
Official Court Jester
Joined 2003
as always ..... BL , centered around 8mA ....... that number being in sweet spot regarding xconductance , associated resistor values and dissipation of part in circuit
however , this one of rare opportunities to toss in whatever you have of Toshiba leftovers (yup- GR and V , too) .... as long you're willing to do some sorting - higher Idss in lower position , lower Idss in upper position in buffer cell ..... and then play with source resistor in lower half , to tidy output node voltage level
Dear Nelson,
Every one has some opinion on LX-mini or open baffle.
We will miss papa amps if we built LX-mini because it requires 100W+100W.
we are running full range with 20W+20W.
So what is your point of view on LX-mini or open baffle with probable FET class AB or chip amps.
It is just some curiosity.
Thanks.
Nag.
Joined 2010
Nelson, an excellent article, thank you.
Any suggestions for power amplifiers that will drive the LX-mini will be welcome.
If they are running in AB class even better.
I think 4 amplifiers running in class A, they will provide a lot of heat (and the summers are really hot in Greece).
Reactions: 1 user
Dear Nelson,
Thanks.
Nag.
I run F6 for the higher frequency driver and a 100W amp for the woofer... Sounds great and I don't think I hit exceeded 20W on the F6 with high volume.
Questions about J113 buffers.
J113s in what range of Idss are usable in the circuit?
In the article Nelson says 8 pairs of jfets draws about 75mA and I guess Idss of each J113 should be more than 9mA. J113 datasheet says min. Idss is 2mA, and I'd like to make it sure.
Another question is when I match jfets, should I match them first and put source resistor(R1)? or should I match jfets with source resistor(R1) in place?
Thank you.
