Passive Crossover Build Help
"The question is whether we can make a crossover at all without measurements - and the answer is NO.
It cannot be done, and crossovers cannot be calculated."
+1
Without measurements it's like working in the dark.
At the crossover point you need to see how the drivers interact to get the phase and FR good.
Here are 4 measurements of the mid and tweeter of my latest project, the yellow graph is with the tweeter wiring inverted to check the phase.
Impossible to do this without measurements.
I measured those with the following setup:
- calibrated Monacor ECM-40 microphone
- Behringer UMC204HD AD/DA
- inroom measurement at 1.10m distance, height between mid and ribbon driver
- REW with frequency dependent window of 8 cycles, no smoothing
