Simple High Performance DC Coupled Class A HPA with sub PPM THD
Founder of XSA-Labs
Joined 2012
Edit April 5, 2019: Beautiful example of this amp in finished case by Avtech23 on post 425.
747613d1554435767-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-sherpafinished1_dxofpr-jpg
747614d1554435767-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-sherpafinished2_dxofpr-jpg
This is a simple DC-coupled high performance SE Class A headphone amplifier design by member TimS who has approved this GB. The design uses four cascoded BF862 JFETs on the input stage. They provide compensation for DC drift and the amp has stable DC offset of less than 5mV. The design has a dynamic CCS, reminiscent of an Aleph to provide good efficiency and low distortion from two P-channel MOSFETs in the output stage. Simulations show very low THD in the sub 1 part per million (PPM) range for 5vpp into 55ohms for a 400mA bias current. At this bias, the heat output is about 14w per channel and allows it to be used as fleawatt speaker amp and able to drive 8ohm speakers to 1.5w with 0.004% THD. Increasing the main source/drain resistors to 2.7ohms sets the bias current at about 115mA and this has very good performance. I built a hand etched prototype and measurements and listening shows a very powerful, dynamic, and clean sounding amplifier. The GB boards will be high quality 1.6mm thick with 1oz copper and ENIG gold finish with blue solder mask.
Here is LTSpice schematic and DC setpoints for simulation:
685372d1528348988-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-simuation-schematic-v3-png
Predicted FFT for 5vpp into 55ohms with 400mA bias:
685377d1528349430-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-simuation-400ma-5vpp-42ohms-fft-png
Here is hand etched prototype:
685071d1528188075-simple-performing-headphone-amp-img_1820-jpg
Measured FFT for 115mA bias 1vpp into 42ohms - note that elevated H2 distortion peak is probably a component choice of the lwo cost prototype (cheap steel leads on resistor, etc). I am quite sure that a proper amp using a real PCB and all high quality resistors and MOSFETs will be superior:
685361d1528330028-simple-performing-headphone-amp-tims-simple-hpa-1-0vpp-42ohms-fft-png
Measured 1kHz sine wave at 17.6vpp for 115mA bias and +/-15v rails for almost 1wrms into 42ohm load
685358d1528329940-simple-performing-headphone-amp-tims-prototype-test-1khz-sine-clip-jpg
10kHz 2.5vpp square wave - nearly perfect performance with no overshoot, or ringing:
685359d1528329940-simple-performing-headphone-amp-tims-prototype-test-10khz-sq-wave-jpg
This is the schematic for production PCB:
685373d1528348988-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-timss-final-schematic-prod-png
Here is the layout by JPS64:
684977d1528123994-simple-performing-headphone-amp-5b1e1d98-a607-4bd7-bf35-7935a0f78e8d-jpg
Here is 3d render of PCB with components (bottom side):
684975d1528123994-simple-performing-headphone-amp-c96ec7c8-2f08-47ac-9ea1-90d82ccd56d6-jpeg
3d render of PCB with components (top side):
684976d1528123994-simple-performing-headphone-amp-fbedc091-3dcd-42a5-8ec0-2aafb59eb563-jpeg
How does it sound? Very dynamic, transparent, open with deep deep bass. It is DC coupled in and out so there is no capacitor to color the sound. The distortion is very low and you have to be careful not to play your headphones too loud if you are used to judging loudness by distortion. It's a great little amp that is easy to build with relatively low cost parts, yet is very high performing. Compare the predicted distortion levels with amps using 5x as many transistors. The nice feature about this amp is the rather high output power it is capable of and a rather high gain close to 20dB that allows one to drive an inefficient set of planar magnetic headphones to loud+ levels with very low distortion.
If there is interest, please add your name to GB interest list. Cost will be about $28/set and shipping will be $5 in US, $10 in Canada, $15 everywhere else.
Update July 3, 2018;
The FFT of the wall mains powered 12v to the on-board ultra low noise DC-DC dual rail PSU has noise characteristics resembling a battery. Note total absence of 60Hz/120Hz/180Hz/240Hz mains peaks and how low the "grass" of the noise floor is:
688827d1529986528-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-hps-dc-dc-psu-142ma-1-02vpp-47r-fft-2-png
Here is the final design for production, and it is an 8 panel board that contains:
  • input and source switch board (only preamplifier version)
  • crossfeed board (with defeat Xfeed ON/OFF switch)
  • headphone jack output board (6.35mm stere TRS output jack)
  • volume potentiometer board (with the possibility of three different types of pots)
  • PSU (includes CLC, DC-DC dual rail step up, cap Mx, CRCRC filter to produce battery-like rails from simple 12v wall-wart)
  • CLC filter board (in case you want to use your own PSU)
  • ON/OFF switch board
  • amplifier board
The above boards can be mixed and matched and connected for either an HPA or a preamp following this diagram:
689951d1530589553-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-simple-hpa-block-diagram-png
Schematics and other data here:
Simple High Performance DC Coupled Class A HPA with sub PPM THD - Page 10 - diyAudio
Top side:
689952d1530589553-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-shpa-pba-top-2-jpg
Other side:
689953d1530589553-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-shpa-pba-bot-2-jpg
Mounted in a popular all CNC'd $36 Aliexpress case as a HPA, it looks like this:
689422d1530307921-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-hpa_front_2-png
Here is rear view of HPA:
689423d1530307921-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-hpa_rear_closed_2-png
As a preamp with your own machined panels, it looks like this:
689375d1530286481-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-preamp_open-jpg
Rear view of preamp:
689374d1530286481-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-preamp_rear-png
Edit July 21, 2018: final schematics and stuffing guide here:
Update Aug. 4, 2018: Schematic Update! Please use this schematic for the PSU as the original has a few typos.
Update Aug. 5, 2018: Silkscreen on PSU PCB has error: Diode V241 has cathode and anode flipped.. Mount diode with Anode towards Drain of P channel MOSFET on cap Mx.
Update Aug. 27, 2018: verification build of GB boards completed. Amp sounds superb and measures very well. Here is FFT for 1vpp into 51ohms - very similar to earlier measurement but much lower distortion.
699591d1535270403-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-shpa-gb-build-01-jpg
699790d1535317831-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-shpa-gb-verif-build-fft-1-03vpp-51ohms-png
Update Sept 2, 2018: BOM from verification build can be found here.
Simple High Performance DC Coupled Class A HPA with sub PPM THD - Page 24 - diyAudio
Founder of XSA-Labs
Joined 2012
I got the amp all boxed up. This one was actually easy to work with as IEC, power switch, RCA, 1/4in headphone jack out, volume known, and LED hole were all predrilled. I just had to mount the amp MOSFETs and PSU and trafo.
attachment.php
attachment.php
attachment.php
Founder of XSA-Labs
Joined 2012
JPS64 and I are working on an integrated compact dual rail supply on same stereo board to make this project a lot more user friendly. We are thinking maybe simple Class 2 wall wart trafo to power a nice DC-DC dual rail step up, followed by state of the art TI ultra low noise LDO linear regulators and then some additional filtering.
A standard linear trafo and CRC and 7815/7915 works but FFT floor is not flat battery quiet like the way I like to see it. Inaudible of course but bothers me that it’s not like a battery.
Founder of XSA-Labs
Joined 2012
GB interest list for TimS Simple HPA:
I am assuming BDHM and YOB are also interested then?
Badboygolf16v - 1 pair
Dabore84 - 1 pair
funch - 1 pair
kartk - 1 pair
Yourownbuzz - 1 pair
BabyDontHertzMe - 1 pair
Although the board may be getting respun as integrated stereo with built in PSU do not sure if “pair” is correct term.
hey X thanks for the mention! if it requires dual rails I may be out - not really confident with mains AC/transformers. Actually this is what is holding me back from building speaker amps.
but if you do manage to get it running off a wall wart with DC step up and splitter etc I'd be up for it!
This also looks pretty cool too - would you be making up any HPA boards? (however would also be waiting on a wall wart/DC step up solution for the dual rails)
http://www.diyaudio.com/forums/atta...ier-trilogy-plh-jlh-amps-quasi69-build-01-jpg
Founder of XSA-Labs
Joined 2012
That's the plan - JP and I are designing it as we speak and I am ordering parts to proto on breadboard before we commit to ordering full blown integrated PCBs with PSU's.
GB interest list:
Dabore84 - 1 pair
funch - 1 pair
kartk - 1 pair
Stellarelephant - 1 pair
