Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoder
That is great but did you post this in the wrong thread?
He was using my DoP decoder. But he had problem with playing DSD128 music files.
He thought it was hardware issue. But finally he confirmed that the software he used was not capable for DSD128 and PCM352/384KHz.
After he switched to piCore Player, the problem was solved. Now he is very happy with the DSD128 output from my DoP decoder.
That's the story;).
Ian
That's the story;).
Ian
pCP is a very lightweight, optimized player, so maybe a Pi3 does not have enough horsepower to play DSD128 unless with something like pCP.
Wonder if the new Pi3 model B+ would do any better?
Randy
SUCCESS YAYYYYY after a longe fight(with volumio and moodeplayer) i tried the latetest picoreplayer 3.5 audio optimized version and now my soekris Dam1021 can play DSD128 HURRAYYY :D i everytime dance when i see the small led on ians board light up when it shows true DSD stream :) also the serial port of the spoekris says L05M which is DSD128 5.6mhz yay :D and i have to say the picoreplayer is overall very nice! the logitech media server works fine AND before my Soekris didnt like 16bit 44.1 files now they play like a boss D: i also have the ardam board from dimdim running and this also works fine :)
Settings i need to make in the picoreplayer to make it work:
for my Soekris DAM 1021 i used:
-on the main page scroll to the bottom and then check the beta tab
Squeezelite settings:
-Generic/simple ESS9023 DAC
-under the DAC is "card control" tick that and tick 384k
-on the bottom "Set Squeezelite Binary: Native/DoP DSD Squeezelite Squeezelite with DSD (DoP or native) patches."
-and finaly add Device supports DSD/DoP: 0:dop
this worked for me :)
hope that helps
cheers janosch
Hi Janosch,
Where did you download Logitech Media Server (LMS)?
Is there anything needed to be setup for DSD/DOP playback on LMS?
What remote control app do you use?
I use squeezebox on my iPhone, do you?
Ian
hey ian :) i installed LMS from within picoreplayer YouTube this video helped me alot :)
lms is only the server there you dont need to set up anything
i just bought iPeng 9 which costs 10€ but its well worth it very nice remote i like it the free one i didt find :D when i looked for squeezebox always ipeng 9 poped up so i bought it :)
cheers janosch
Hi Janosch,
Ian
Hi Ian,
Months ago I did send you a complete "manual" of how to install,config and where to download all stuff.
Here's a quote of a part from that email:
"From what I understood is that latest version PcP 3.22 can work with I2S and FIFO II, but I didn’t try this myself.
PcP version 3.22 is available in standard and audio optimized version. The Audio optimized version can play 384kHz files, and DSD (from what I understood).
Someone of the PcP team told me the “Hifiberry DAC zero/miniamp” driver should work with I2S.
If you can manage to get it to work with this driver, in combination with LMS 7.9 server, you should be able to play DSD too.
PcP download site: Download - piCorePlayer
LMS 7.9 site: Some Software Beta Downloads - Version 7.9
Alex
IsolatorPi II
Besides all the features originally from IsolatorPi, what are the new updates on IsolatorPi II?
1. IsolatorPi II now supports 502DAC Pro, Hifiberry Digi Pro +, and all other WM8804 based master clock mode applications;
2. IsolatorPi II has the optional 40Pin non-isolated GPIO connector pre-installed. With which, we can connect the possible ESS DAC controller, Ir receiver, the rotary encoder and all other non-audio devices to RPi. The good thing is that all of those devices will become 100% isolated from DAC under this configuration.
3. With IsolaporPi II, now we can power RPi from GPIO (reported better than USB power) through the no-isolated GPIO connector, or, from the +5V and GND Pins beside if that GPIO is occupied.
Ian
IsolatorPiII_1
by Ian, on Flickr
IsolatorPi II was tested working perfectly with 502DAC pro.
502DAC Pro is an audiophile grade DAC HAT. The sound quality is amazing. It has almost everything: PCM1792, master mode WM8804, S/PDIF output, balanced/se output, and LME49600 headphone amps. It's the best DAC for RPi so far I've ever listened.
It can benefit the most out of IsolatorPi II because it works in master clock mode. Clean isolated 5V DC power supply will power 502DAC Pro from the IsolatorPi II. 502 DACPro takes awesome current around 1A. Red/Yellow LED will be switching when music switches between 44.1/48KHz Fs groups.
But too bad it's been discontinued. Michael told me that price can not cover the cost. I think it's true.
IsolatorPiIIand502DACpro
by Ian, on Flickr
Ian
Ian
IsolatorPiII_1
by Ian, on Flickr
Finally, we can no longer use the USB power!
by Ian, on Flickr
Ian
Interesting. I have just bought one of the early review versions of the new dual PCM1794A DAC from Orchard Audio: The ApplePi DAC. I'm listening to it in a a stack with IsolatorPi and Allo Kali and the sound is very good indeed. It certainly betters my previous RPi faves, which were Allo Kali/Piano 2.1 and Terraberry DAC2.
Joined 2003
@jonners,
I had the tour ApplePi DAC here for a short listen. I had it on an Allo.com Isolator & Kali stack, powered with:
- The base RPI via a viaa 5V upgraded K&K Audio low voltage power supply.
- The IsolatorPi and the Kali each powered from another LPS-1 each for 2 total.
- The ApplePi via a dual 5V Stammheim 3||LT3045 board with each side powered from an Uptone Audio LPS-1.2, so 2 in total for the DAC board giving a full 2A output capacity.
I also found it very good, just surpassing Ian's prototype single ES9028Q2M DAC board with Onetics 600R:600R transformers as the output stage in the Joe Rasmussen configuration.
The only drawback for me was a touch of 'digitalitus' to my ears, likely from the DC-DC converters used in the power sections (I experienced similar using a Silent Switcher on the Dial DAC). BUT that doesn't detract from how good it was and I'm not sure others will notice that as I did.
My Soekris DAM 1021 setups surpassed it... and while I didn't have my Buffalo-IIIPro setups running at that time, I've gotten them going since and they do too. BUT all at significantly higher cost for the DACs, output stages (for the BIIPros), and power supplies... and MUCH larger footprint.
I'll be working on the trial version of Ian's UCPi supply this weekend and hope to be powering his prototype DAC with it later this weekend or sometime next week. Curious how his prototype DAC board powered by that!
Greg in Mississippi
P.S. I also am waiting for the updated Allo Katana. RPi DACs are pushing upwards!
@Greg,
i'm not using such elaborate supplies as you (Who is?!). I have iFi iPowers to the RPi and Kali/DAC and an Aqvox linear supply to the Isolator. I thought the DAC without IsolatorPi and Kali was good but a little bit fatiguing to listen to, and maybe that shortcoming has not entirely gone away with my present setup.
I shall look forward to seeing what Ian's UCPi supply can do.
John
by Ian, on Flickr
Ian
Waiting so long! How about the order, please?
Hi Ian
I have looked at your IsolatorPi and have a question if it could benefit my setup. I am using a COD DAC (PCM1794), Metronome ASRC Reclocker module (SRC4192) and dual power supply from Twisted Pear Audio(TPA). The I2S signal is feed from a RPI 3 through a selector switch.
The DAC is feed from the TPA dual low noise power supply (LM317) with one channel for the analog part and the other for the digital. The digital part is also supplying the ASRC module. The RPI has it own Chinese linear power supply from ebay.
Would you reckon that the IsolatorPi would improve my system and then use the Twisted Pear Audio PS instead?
Would it be possible to power the IsolatorPi with 7.5v DC (voltage of the PS from TPA) or would that increase the voltage to much for the LDO?
Would the Isolator I and II both work if I have attached buttons and a LCD to the GPIO?
I have attached a schematic of the power wiring. (I also have a analog stage (IVY) and a SPDIF module...)
Thanks in advance :)
Regards Mikkel
Power supply Low Current Dual Power Supply (LCDPS) - A Dual Regulated CRC Supply
DAC: The COD - Current Ouput DAC
ASRC: The Metronome ASRC Module
Hi Ian
I managed to get hold of a IsolatorPI from a fellow DIYaudio member. The board is very nice and have already installed it with great succes.
I have been messing a bit with the master/slave jumbers on the IsolatorPi. I can only get it to work in slave mode. I have connected the I2S signal to a SRC4192 ASRC module from Twisted Pear(Metronome). The board is set to output master mode at 256fs. That signal is passed on to a PCM1794a COD DAC also from Twisted Pear.
Maybe i have misunderstood the Master/slave idea but do you know why the master jumper setting is not working?
Thanks in advance:)
Btw: Your new FifoPi looks really good! That could be the newt upgrade ;)
