Replacement For Toshiba 2SK170/2SJ74
Joined 2012
This is correct for the average FETs. In practice variation is quite big and to do the job well you will have to actually measure the FETs and find those where it works. But as I understand that is not your cup of tea as long as somebody else spoon feeds....
By the way, I did buy and test a couple of those Toshiba 2SJ74-GR you found at Reichelt.de and they are indeed fakes (way to low transconductance).
I have been measuring different JFET´s and found nice matching curves with a 2SK170 of 8.2 mA and a 2SJ74 of 9.0 mA and around 2.4 Ohm extra resistance for the 2SJ74, 5 Ohm was a bit too much. The higher Idss the JFETs are, the lower the difference between the two resistors can be.
But like NicMac said you have to measure them individually to get good results.
I think I posted it here, if you extract the beta parameter over a reasonable set of operating conditions the basic FET equations can give you good results even with equal degeneration resistors. I recently sorted 170/74 pairs for 0 offset with 25 Ohms in both sources, and still got 0.003% THD at line level. It's a no trim solution. By no trim I mean that zero offset and (near) minimum THD can be achieved without pots.
As for using trim pots I posted years ago the complimentary JFET input stage where the current ratios could be trimmed. You have two degrees of freedom you can trim offset and drift to 0 or offset and 2nd harmonic to 0 all with totally unmatched FET's.
"As of Jan. 2018, we have yet to begin sorting the parts we have in stock, so give us a few weeks to get enough stock built up."
So they start selling before they have measured all there 4k stock.
You can guess how well the match could be from a smaller pool.
And as we have mentioned before, claiming sub 1% match has no meaning if you do not apply temperature control.
Just try gently breathing on a JFET running at Idss, and see how much the current changes.
Patrick
Ebay vendor show his jfets are curve traced :)
