DD Z2 bursts output transistors
this pulse is what I get in the collector of q7 and q9
That's probably because the rail voltage is so close to ground. Do you have a small (no high current needed) 12v power supply with an output that is completely isolated from ground?
A 9v battery may also work.
Whichever you have, connect it to the negative rail caps. Negative terminal of negative rail cap to the ground of the supply or the negative terminal of the 9v battery. Monitor the temperature of the 9v battery. It may get hot charging the caps.
Does that give you a better drive signal on those transistors?
