And what did we buy today?
Just another Moderator
Joined 2003
Yes I suspect I will probably only use the mid or high modes, very rarely the turbo. Most of the places I ride are bike tracks through wooded areas with no lighting so a bright light will be welcome. The one I have at the moment is 200 lumens, which is ok. It shines a reasonable distance but has a fairly narrow beam and also shines in joggers and other bike riders eyes.
The low beam on this one should be better than that and not shine in anyones eyes. For when it is clear I can press the remote button to switch on the high beam! Ever since I was a kid (I used to ride quite a lot at night) I wanted a bright headlight with low and high beam, so I was rather happy when I found this :)
edit: on the early leds. I remember when the first 200mcd leds came out, and thinking wow that's bright!!
Tony.
Harmon Kardon Onyx Studio 4 Bluetooth Speaker (also accepts mini input)
Quick A/B between a pair of Nakamichi S-1A bookshelves through a Copland Integrated and a Mac mini- no contest. Obviously speakers were the bottleneck, but it wasn’t a shabby comparison. I now feel stupid even clearing the shelf space for the other stuff.
Retailed at $450, selling from HK for $250 but routinely found online now for ~120. For the going price a no brainer for me for non-critical, ambiance listening. I bought it unheard after a bunch of looking into similar offerings.. glad I did. Especially impressed by the bass clarity in this little guy (about the size of a salad bowl turned on its side).
Now considering getting a second for stereo.
Harman Kardon Onyx Studio 4 | Portable Bluetooth Speaker
PRR
Joined 2003
I "upgraded" from TimeWarner innernet to Spectrum. Got a "new" innernet modem. The dang thing has different failings every time it powers-up..... ........ .........
...a week later...
AND.... total fail. Their modem kept going offline, forgetting the settings, stalling, and generally acting too cheap to live. Today it woke up dead (reboot loop).
Got a guy out and he agreed the Technicolor was not working, got an Arris out of his truck and also a Wi-Fi router (I like separate boxes anyway).
2 hours so far....
I bought the components for a USB and microphone mixer.
I cheat and buy in the USB audio DAC and wire it into my own mixer.
It can be for general purpose use or used with a laptop for a disco setup.
I also bought components for a speaker DC protection unit.
Slightly novel circuit as it uses a PIC micro input pins to monitor amp out signal.
The signal is split with resistors to reduce input voltage.
A PIC pin changes state at 2 volts and this is used to detect +/- DC.
If the PIC see's DC for 500mS or more it turns off the relay.
Administrator
Joined 2004
...a week later...
2 hours so far....
I purchased an Arris Surfboard back in December for the Comcast Xfinity service I contracted for. So far so good, quite pleased with the performance, I get up to 300mb/sec transfer rates (not a typo). This replaced the unreliable, rickety, slow Verizon DSL we had since we got here way back in the dawn of the new millenium.
Arris Surfboard
Arris bought the Motorola cable box division when the wall street wizards orchestrated a break up of the company. The Surfboard was a Motorola branded modem for a dozen years or so. I believe that Arris selss under the Arris brand and the Motorola brand, and private label for large MSO's like Comcast.
we are a few miles from nowhere on a Comcast system that is about 15 years old. The TV pixelizes all the time, and the phone drops calls, but the internet.....I just ran a Speedtest and got 302.06 download speed. I can stream two 4K videos at the same time without issues.
Disabled Account
Joined 2017
I spotted one of these nifty little tools on a youtube video while browsing diagnosing fuel injector videos.
Automotive Car Spark Plug Auto tester Indicator Tool | eBay
YouTube
You simply hold it in your hand and tap it to the side of any spark plug lead and it turns a neon light on. Amazing!
I suppose it will give you a nasty bite if you have a leaky lead :)
Disabled Account
Joined 2017
Thanks heaps!
Although I have an EFI car it is only OBD-1 with an adjustable AFM cog and ordinary distributor. 3VZ-FE engine.
Theoretically I could modify it to run on pure E85, but the price would have to drop more (and more available) for it to be justified.
A properly tuned Flexfuel car will get about half the gas mileage from E85 than it gets from gasoline. These facts are documented somewhere in the sales literature, but not always obvious.
Ethanol has a lower BTU / liter ratio than gasoline, so it takes a lot more of it to make the same amount of heat. It also has a much higher octane equivalent (resistance to detonation) than gasoline, so it's an excellent fuel for racing in a properly equipped engine.
