All , please sign up to commit your interest in this, and I will send out billing for it.
I dont want to manually put in people who may not be currently interested.
I misworded this previously. I recommend ordering the pins for it from me, it makes the board go together easier, and allows setup of Front end first before getting back end on.
Luke - 2 pair of FE boards only.
RainfallSky - 1 pair of FE and Output boards.
Telstar - 1 pair of FE and Output boards.
dsdjoy - 1 pair of FE and Output boards.
sorenb - 4 pair of FE and Output boards. + 4 pair of FE
arky - 4 pair of FE and Output boards
zeroalbedo - 1 pair of FE and Output boards.
Hi Teabag - the spreadsheet was not editable by me, so I'm adding myself here for 2 stereo sets, with connectors and anything else available for it.
bkdog - 2 pair of FE & OP boards, all connectors, & anything else available for this build.
Many thanks!
Many thanks!
MASantos: read message #27 (http://www.diyaudio.com/forums/grou...-version-2-al-boards-tea-bag.html#post4885036), please.
Tea-Bag, so sorry I just checked my set of 2SJ20/2SK82s. Much to my regret I should give up my plan to build a 2nd Sony VFET2. Delete me from the ongoing list, please.
No problem.
My guess is that several people here are going to build based off one pair of VFETs and not populate certain sections of the board, and use Nelsons values for the Single set. I have not compared the topologies. If someone can screenshot it and attach it here. It may become more obvious, or hack the one I have posted to comply. If so, I can edit the first post to include that.
I have a pair of extra boards for the single pair version if you are interested.
I'm about to start building this amp - I'm never quick, perhaps I should say I'm gathering the rest of the components now that I have the PCBs and the VFETs... Hope to have a build finished by xmas.
How many others are building it & should we start a build thread? At the moment I'm struggling to find the L or Tee section aluminium to mount between the PCB and the main heatsinks, so if anyone has any hints I'd love to hear it.
I used 2" x 2" x 0.25" 6061-T6 Aluminum T-Bar from onlinemetals.com: 2" x 2" x 0.25" ALUMINUM T-BAR 6061-T6 - Online Metal Store
Maybe modushop in IT. I'm in Australia and I found them by searching locally for "Aluminium Tee section". I found a place that had 50mm x 50mm x 6mm (yes it fits, I checked) and would cut it: Tee Section, T Beam, T Bar - Handy Steel Stocks
- Group Buys
- GB Pass SONY VFET Version 2 - AL Boards by Tea-Bag
