2A3/6A3 tube preamp
Hi
I want to DIY 2A3/6A3 preamp
I want to know my schematic is work or not
Attached the schematics of power amp and preamp
Please give some suggestions to me
Thank you !
PRR
Joined 2003
...I want to know my schematic is work or not...
Work? Make sound? Yes, if built right.
Work? Be a good music playback system? I think it does not have enough gain to work in most systems.
The 417 stage does have good gain. The next 2A3 stage has very little gain to plate. The 2.5K:2.5K is unity gain. Then the 5K:16 plate transformer has voltage LOSS of 17:1. So two fancy tubes and two transformers for almost no overall gain.
Why a 16 Ohm output on a preamp?
Married to the power amp: the 805 grid needs a BIG driver. I'm not sure a single 2A3 will do. In any case the 2A3 will need about 45V peak at its grid to make full output. Since your preamp gain is 2.5 (maybe 3), this means you need a VERY large signal into your volume pot.
Are you looking at transformers in hand and trying to make something?
The power amp is working now with my 417A one tube preamp
I want to DIY new preamp (417A+2A3)
I have 2.5K:600 replace the 2.5K:2.5K
The preamp output transformer can replace by 5K:600 ?
The inter-stage transformer of the power amp is 2.5K:600
My first schematic
LOL It's a little overkill, no? Seems like a giant waste of a 2A3... Almost as daft as using a KT88.
Hmm KT88 preamp you say... Tell me more :)
Honestly if the pursuit for the ultimate in sound quality and enjoyment I believe nothing should be taken off the table. If someone were to build a 300B preamp (or 2A3 or KT88) and demonstrate that tubes of all kinds should be considered, I'm all for it.
Oh, and I should also say that sometimes I think we all should try something just for fun and to see what happens.
