FS - chokes
Two 127mH/3A/rdc:0,5R EI(105) chokes vacuum backed
used for the Choke loaded OTA designed by Tyimo but also good for the MoFo .Not planning to go further with the MoFo
Price 100 Euro+ shipping cost for the two.
I only have the small version with 14 Vdc never got the 30 Watt version .
To bad maybe that amp sound better than the MOFO. I made several types of PC boards to Tyimo but that was more than 5-6 years ago. My relation with Tyimo deteriorated (he was too busy to answer my e-mails so I stop writing to him.
I would still interested in that amp if I have the circuit at least. :)
I do not see that schematics on the forum. I think you ordered these transformers from Hungary with the help of Tyimo. Can I ask why you changed your mind to not to build these amp?
Greetings
Greetings
Which amp do you mean , the MoFo ?
My chokes are made by AE Holland
Yes the MoFo VS Tyimo's amp.
I was wrong, I thought it is from Tyimo from Hungary, at that time I wanted to order a pair choke and Tyimo offered me his help but the shipping cost very (horrible) expensive.
He also told me some other DIY-ers from EU ordered those chokes from Hungary by his help. So that is where the confusion.
Disabled Account
Joined 2002
Hello,
Will use them for choke input for a class D 2.1 ( Virtue sensation m901) in my home cinema set. The batteries i used are about to go dodo after a 3 years or so. Can probably use a transformer i have in stock in the attic.
By the way, if used with 80 hertz/cycles input filter ( lower frequerncies will be taken care of by 2 active SVS subwoofers) the current drawn by the circuit will change?
The transformer could give a little bit to high output so might have to add a second choke . Being class D amp it could be hard to achieve a steady voltage drop. I might go for anopther transformer and just create a LCRC filter.
Greetings, Eduard
