Thanks for the kind words and amp suggestions. After free handing the first rebate, I thought, if I do more than one of these I oughta build a jig!
I'll have to look into those amps. Right now I'm working on a TDA7297 to replace the Lepai in my traveling rig. My brother thinks he wants a little Chi-Fi tube amp to pair with his uFonkens but I'll relay your suggestions.
Good to see another South Carolinian here, Poultrygeist!
Doug
Doug
My new PC-Speaker EITHNE
My new PC-speaker Eithne using a PEERLESS/VIFA TG9FD10-08 in 3 litres bassreflex
-3 dB @ 57 Hz
-3 dB @ 57 Hz
Here's my current desktop speakers, Tangband W4-657SC in 5,5 liter reflex enclosure tuned to 65hz. Optimal box could be smaller and tuned higher, but I wanted to extend the low end response a bit. Made from 18mm MDF and painted with white rubber coat, nice and different finish but hard to keep clean cause dust sticks to it.
Source is PC -> nuforce DAC -> DIY TDA7375
Needed to document this because nearly the whole system is getting an update [emoji6]
A few years ago I picked up what was left from a pair of TQWT speakers I have given to my oldest son. The nice Fostex TW15 tweeters were burned, propably due to amplifier clipping, and the bas/midrange - Fostex FE164 - were OK but the cones were slowly loosing from the chassis (bad glue?). I managed to glue the cones back and didn't want the drivers lying around and eventually selfdestruct, so I bought some boards of spruce, run som simple calculations using online software and came up with a pair of ... well ... .
Did just make the final installations (some kind of filling, cheap terminals and drivers) in order to use them tomorrow with my other speakers, when the HiFi-guys are coming.
Nothing fancy. Haven't even sanded them nor painted/tinted/oiled/waxed them, but they sound OK.
Thanks. It would have felt bad if I had ditched them.
Tomorrow we are 4-5 Audiofooles, gathering in my place for lunch, music and tons of talk.
Will present some 2-way speakers I finally took in production (listening production), and the FR-speakers will be nice to use in comparison.
I managed to find Alpair 7.3's from CSS and with help of Dave at Planet 10 who designed the internal "holey braces", I built two more pairs of columns that I'm really happy with. They vent to the rear via 4 rectangular vents. ]
I had to try. First image uoloaded by the image tag, the other using the attachment manager.
The speaker was a project on a shoestring (excuse the pun). Now scrapped.
(Something went wrong when I tried to fix a speling errur)
A few years ago I picked up what was left from a pair of TQWT speakers I have given to my oldest son. The nice Fostex TW15 tweeters were burned, probably due to amplifier clipping, and the bass/midrange - Fostex FE164 - were OK but the cones were slowly loosing from the chassis (bad glue?). I managed to glue the cones back and didn't want the drivers lying around and eventually self-destruct, so I bought some boards of spruce, run some simple calculations using online software and came up with a pair of ... well ... .
Did just make the final installations (some kind of filling, cheap terminals, and drivers) in order to use them tomorrow with my other speakers, when the HiFi-guys are coming.
So, Magnus, the single full-range driver bug has struck you again?
Thetubeguy1954 (Tom Scata)
Oh, forgot: this is what is expecting me in a couple of weeks: HiFiForum.nu - Sonido SWR 096A Ellips
Not my equipment.
Not my equipment.
i have attached John’s (Impunity) pictures to his post.
This polygonal cyclinder is actually a deciSize Mar-Ken (9 litres) with an elaborate holey brace to create the vents out the back… now i have to figure out the detail of what i did to figure the same thing for A10.3
dave
dave
I finally got some 25-50W klass D amps up and running to use with new speakers and made the last adjustments to the pair of un-orthodox 2-way speakers.
When looking at the X-overs and the costs of the X-over componets, I 'd rather stick to full-range speakers.
You don't need xover components and all the nasty things they do, you can disappear down the rePhase rabbit hole instead
Prior to using the Alpairs, I had tried some Tang Band W4-1879's but they got a bit pricey when the $ took a turn a couple of years ago. The Alpairs are sweet though and I'm keen on Trying the 10.3's. I guess that's another thread seeing as this is a photo gallery.I managed to find Alpair 7.3's from CSS and with help of Dave at Planet 10 who designed the internal "holey braces", I built two more pairs of columns that I'm really happy with. They vent to the rear via 4 rectangular vents. ]
Not my equipment.
Magnus, what made you decide to try the Sonido oval SWR 096A as opposed to the Sonido SFR 200A 8" circular driver?
- Full Range
- Full Range Speaker Photo Gallery
