Opamp Passive RIAA questions
I'm just beginning to step my toe into the murky waters of phono stage design, and I've noticed there can be considerable variation among simple opamp-based passive RIAA designs in the series resistor value, with the pursuant changes in the other RC components. Attached are a couple of examples.
While the opamps used in each schematic have some differences -- input voltage noise among them -- they both are capable of driving low impedance loads with low distortion.
Why would a designer choose one approach over the other?
My apologies -- I'm certain this has been asked and answered many times before, but I can't seem to find or discern an answer
gtrmkr
2nd option looks better. But some components are missing:
- a series resistor between the second opamp and output (100R)
- bypass capacitors at + and - Vcc to GND (.1uF ceramic)
There will be also some DC at the output, so a series capacitor could also be useful.
Hard to say. The only excuse for the high impedance network is the belief that a particular opamp sounds better into higher impedance loads. At some stage, a long time ago this was perhaps true.
Personally i do not like the subjective effect of high resistance in series with the signal. My current opamp riaa has no such resistor at all.
