DAC gallery
Not sure where I should be posting but are there any guides on a DIY DAC?
I don't mean some discrete R2R DAC or anything like that I mean using ICs. My knowledge of coding is near zero same with fair bit of the digital design side. Got no problem with analogue though, anyone know of anything?
Ultimately want low THD (<-115db THD) and noise, again analogue electronics side is no problem.
Was thinking of a ESS9038pro?
But as I have had no experience anything I could start with to learn?
I do not like the ideea to have în the same package complex digital schematic together with low noise analogic circuit. I simply do not have trust that The digital noise will not go in the analogic low noise circuit. The measurements can be easy made to show low noise and distorsionează by simplu don't measure în the right spectrum zone.
This is my favorite dac, LemonDAC.
Wolfson WM8805 receiver, Sabre9023P DAC, Atmega1284p Controller.
Salas pre-regulator, 8 super low noise dc-dc converters (LT3042, TPS7A4700x)
Individual PSU for controller, display and usb receiver.
The engraving of the case has be made on a diy CNC.
Outside view of the dac: YouTube
Inside view of the dac: YouTube
Really like this!
Finally I finished my DIY DAC project
2 SPDIF, 2 optic, USB (xmos), Raspberry pi3 > FIFO > sm5847 > PCM1702 > Nazar out
Outside view of the dac: LemonDac - YouTube
WOW
Where do you get your casework/lettering done?
Lovely work.
P.
Very nice,
can we have some more pics of the external casework?
Also, where did you get the case? Did it come with those internal separation pieces? If not, where did you source those?
I always find doing the casework the hardest part !!
P.
Hi Percival007,
The case from China (~25$)
And I did internal separation of the plastic (10mm) and the copper tape.
It's good for unti-noise.
Cheer,
why not post here? that is the idea of DIY forum ...
Ok ddac, Thank you for your interest!
My DAC specifications:
1. Pwr supply: LT1963-3015, LM317 and LT1117-5
2. Digtal in, sampling, clk: 74HC00, 74HC86, CS8414, SM5842
3. D/A: 4xPCM63-K
4. I/V, Buffer: 10xNE5534 or equivalent
Number 2 board, 3 board and 4 board conneted by SMA connector and cables
3. D/A: 4xPCM63-K
That's a sweet setup. I thought those were SMA, just wasn't 100% sure from the photos. I would have never thought of using those. I actually use those in a couple of field monitoring devices I have created for clients. Used the IP67 bulkheads which looked bigger than what you used.
