The recording doesn't matter half as much as the reproduction, thank goodness
why should it be that way? It's easier to talk than listen, transmit than receive, I have my own theories on that. But I'm happy that it's this way round re recorded music, because honestly I listen to a lot of very poor quality recordings ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My personal favourites at this time are from Stockfisch Records.
Previously was anything from ECM, Blue Note, Chesky Records.
Maybe these recordings from Stockfisch are too bombastic, like when Michel Chapuis plays Buxtehude works on organ.
But I like very much these records.
I've explored just right now
I discovered just right now that when I saw the temperature figure of Ontario and Minnesota at present in the newspaper, my man-tag interrupted the read by falling off.
(a case of outsitting a pecker)
by falling off.
That is, it was up, from where to fall off, right?
This is a good performance in your age.
it was up
At my age I like morning wood to last, to the first pee, which is after I finished the early newspaper edition.
Aah, the days of stretching it till beyond the afternoon paper.
(alas poor YorDick, he has borne me on his back a thousand times and now, how abhorred in my imagination it is)
trick is to endure
You curtain lot are just too frugal to pee, why have decent pakија and then let it flow to waste in a toilet.
Known locally as a ****fat
I once had a one-nighter with a woman I'd name a peetwat, she asked me to flush the pakија inside her.
As much as I wanted to ple(e?)ase her, I have my physical limitations.
* self-censorship
Known locally as a pissfat
...and in West Wales (Ireland) as 'normal' [....I thought the Welsh called it "Lambfat"]
Yo piplz
Dodossesss , I mean ;
cooling pin for 2SK2145 is Drain , I resume ?
https://toshiba.semicon-storage.com/info/docget.jsp?did=19704&prodName=2SK2145
ZM knows Station ...
- The Pass Pub: The High-End Off Topic Thread
