how can I add an avatar
PRR
Joined 2003
...to access the Control Panel you have to click the "Private messages" link, under the user name.
I think there is a direct way?
Up top, menu-bar, "User CP".
OK, WTF is a CP? -- Control Panel.
Follow the path in the Attached....
It is "direct" only if you see it -in the middle of 15 irrelevant menu items.
One obvious usability "rule" is that relevant information should be put together. In this case, that is inside the box with the user name and the user information, and/or on the user name link as most users expect this, used to other forums. The info "You last visited: Today at 06:06 AM" is redundant. It could be put there, or after expanding the box to make room.
