FirstWatt F6
Hi, i have build F6 amp and i need advise how to set bias voltage. I now this ( starting with a meter across the 0.47ohm source resistor ) but which is source resistor? ( R?).
How i now when trip pot is turned all the way down before turn power on?
Thanks.
R2 0.47 (they are in different places so be sure.
You must start with a current limiting device (bulb tester)
As an example my pots work backwards so be ready for that!
If you have 6.2v zenners fitted start with the adjusters set about half way.
Switch on with the current limiter fitted and watch the voltage across R2, this will rise slowly as the caps charge. (If it seems to run away switch off and try adjusting the pots.)
Just look for enough voltage to start the mosfets getting warm.
Make sure that you know which way the adjuster is working.
Turn down the bias and remove the current limiter.
Start again raising the bias slowly and balancing offset.
It is all in the build guide.
Just finished and i also have build B1 and they sounds great.
My speakers is Cain&Cain Abby but i also have Magnepan 1,6 but i don´t know if F6 have enough power to drive them.
