AKSA's Lender Preamp with 40Vpp Ouput GB
Founder of XSA-Labs
Joined 2012
I just built up the MB and the Vcc power rail test was successful. I am missing some electrolytic caps for the CRCRC but otherwise everything went together pretty easily. I wish the input and output bypass film caps allowed 5mm pitch Wima MKS because I have bags of those. I had to bend the pins 90deg and "surface mount" them on the outputs. Otherwise, and excellent layout. Of course, if you bought the items in the BOM, they would all fit. This test build is using strictly stuff I have on my bench without ordering anything. The signal input/output connector is something I don't have at present, but the wiring configuration is easy to understand: inputs on the two inside pins and corresponding outputs to the outside pins in the lower row, the top row are all GND. I am using an RK09 Alps pot from my pocket amp and attached a short piece of vinyl tubing to allow the shaft to be operated from the front.
Here is a 44.5v DC step up putting out about 40.5v after the cap Mx and CRCRC. I am using a non-ideal 470uF cap on the cap Mx so the slow ramp up takes about 60 seconds to reach full voltage. That's actually nice from standpoint of preventing thumps and other transients. 220uF or 100uF would be fine. One thing is for sure, this PSU will be dead quiet with a flat noise background down at the measurement limit. I have typically seen -130dB and flat.
attachment.php
So I will build up the amp core daughterboards next when I have some more time. All for now...
Founder of XSA-Labs
Joined 2012
GB MB & TH PCBs are Singing
I built up the TH daughterboard using a 12k carbon film feedback resistor and 10R LTP degeneration resistors. Using a BSP129 in place of DN2540. Only one channel built so far. This is with 45V Vcc.
attachment.php
FFT for 8Vpp into 7kohms (THD is 0.00071%):
attachment.php
FFT for 20Vpp into 7kohms (THD is 0.0016%):
attachment.php
If you increase Vcc to 48V, you get THD of 0.0001%, but H2 and H3 become closer together. R9 is currently 100k, reducing that to 68k will increase H2 relative to H3.
Founder of XSA-Labs
Joined 2012
Performance is very similar to Lf353, 351. One of the best op amps ever made
Hmm... the topology is sort of similar on the LTP with diode but JFET Input, NPN on the right LTP leg but wired differently. Also has a push pull output stage vs SE Class A output on this one. LF353 spec says THD is 0.02% - quite a bit higher than his amp.
attachment.php
Joined 2010
Paypal address
The MELF GB is still on. Yes, I will ship to Canada address. Is this the address on your PayPal? That’s where I ship to so that he order can be closed out.
Hi X,
The Canada address is the PayPal shipping address. I know you will ship the board sets to Canada.
I was trying to confirm that JPS64 would be invoicing for the MELF GB, and would need the correct shipping/mailing address. Sounds like everything is OK.
K
Joined 2010
Hi X,
K
Hi X,
I just checked my Paypal account. There is a billing address and a primary address, both of them Mexico. When JPS64 invoices for the MELFS, I will PM him and supply him the Canada shipping address. Sorry for the confusion.
Founder of XSA-Labs
Joined 2012
Here are some suggested alternate resistor values to let you tune H2/H3 and overall level of THD, and amp gain to your taste:
attachment.php
All values on original schematic are good, just order extra values in red to allow adjustment.
As starting values I would recommend R5/R6=33R, R10=6k8, and R9=68k. Have a listen and go from there. Mostly increase/decrease R10 to get the gain you need. With a normal line level source, you will need the 12k to hit the full 40Vpp, but if you have a more powerful DAC with full +/-15v opamp output, perhaps only 6k8 is needed. For use as a line-level amp (not for driving unity gain buffers), 3k3 is plenty as a preamp.
R5/R6 lower values give lower overall THD but higher H3 relative to H2. Higher R5/R6 gives overall higher THD.
Lower value of R9 gives more H2 relative to H3 but increases overall THD.
Data shown above is for R5/R6=10R, R9=100k, R10=12k.
Founder of XSA-Labs
Joined 2012
GB Status update:
JPS64 - 1 set SMT, Paid
Redarc12 - 1 set, TH, Paid
CFT - 1 set, TH, Paid
Jacques Antoine - 1 set TH, Paid
Silasmellor - 1 set THT, Paid
Bvtrinh- 1 set TH, Paid
bvtrinh - 1 set TH (second set), Paid
ggetzoff - 1 set TH, Paid
tubesguy - 1 set TH, Paid
Aatto - 1 set SMT, Paid
Mordikai - 1 set TH, Paid
Johnny2Bad 2 sets total 1 TH & 1 SMT, Paid
vvs07 - 2 sets TH, Paid
PCGAB - 1 Set SMT, Paid
Harry3 - 1 set MB plus TH, Paid
Wayne1 - 1 set TH, Paid
obh - 1 Set TH, Paid
PJN - 1 set TH, Paid
Zman01 - 1 set SMT, Paid
AKSA - 1 set SMT, Paid
xrk971 - 1 set SMT, Paid
spind - 1 set TH, Paid
schlomoff- 1 set TH, Paid
Prasi - 1 set TH, Paid
muthumuthiah - 1 set TH, Paid
Algar Emi - 1 set, TH, Paid
Kokanee - 2 sets, 1 TH and 1 SMT, Paid (moved up from FB2)
—— List for GB #2 - please add name below ——
Thimios - 1 set SMT, Invoice sent
*Fabian85 - 1 set SMT - need PayPal address
Pinnocchio - 1 set SMT, Paid
Mituisho - 1 set SMT, Paid
Alurudin - 1 set TH, Paid
muthumuthiah - 3 sets all TH, ship all with order from GB #1, Paid
jwjarch - 1 set TH, Paid
*jwjarch - 1 set of TH daughterboards only, Invoice sent
briansz - 1 set TH, Paid
*briansz - 1 set of TH daughterboards only, Invoice sent
steefdebruijn - 2 sets TH + spare set SMT daughterboards, Paid
jmc207 - 2 sets: 1 TH and 1 SMT; +1 spare set TH daughterboards, Paid
*marcus22ch - 2 sets SMT, Invoice sent
vanofmonks - 1 set TH, Paid
pfisl - 1 set TH, Paid
*neoinc - 1 set TH, Need PayPal address
I will be sending out GB1 boards mid next week as I will be on travel for a few days. TH daughterboard has been verified to work, but TH so far has not yet as I don't have the MELFs. However, I am pretty confident it will work as layout is similar to TH one except in SMT.
Hi all,
Minimelf MMA0204 1% TK50 and Melf MMB0207 1% TK50 including extra values ordered.
R10 not included:
- CMA 6k8 and 10k0 available at Mouser
- bended 0204 carbon resistor available at Mouser, Farnell and others
One set for stereo for 4€ including shipping worldwide.
JP
Founder of XSA-Labs
Joined 2012
GB Status Update:
*neoinc - 1 set TH, Invoice sent
