Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Official Court Jester
Joined 2003
Sorry, ZM. I don't have that one. :)
Silly ZM ...... I have it in my LTSpice , imported in JFet library eons ago
so , here it is , with SJDP
it needs speaker delay relay , having startup peak , about 10V in first 50uS
at least according to sim .... worth checking in vivo , with soft start etc.
Joined 2009
.subckt SJDP120R085 D G S ; 1200V 100mohm TO-247
Rd D Di 35m tc=9m, 5u ; requires tempco
Rs S Si 35m tc=9m, 5u ; requires tempco
Rg G Gi 500m tc=-3m ; requires negative tempco
Cds S Di 1p ; direct Cds is almost zero
Cgd G Di 2.5p ; Cgd overlap capacitance
Ji Di Gi Si SJDP120R085
.ends SJDP120R085
.model SJDP120R085 njf; Rd, Rs not used (no tempco)
+ Vto=-5 Beta=8 B=0.2 ; dc curves
+ Lambda=.31314 Vk=2k5 Alpha=20u ; voltage influence
+ Is=1e-020 N=3.5 ; sets fwd GS diode curves
+ Isr=1e-020 Nr=1.5 ; sets rev leakage
+ Cgd=500p Cgs=200p Pb=1.6 M=1 ; nonlinear Cs
+ Kf=1f Af=1 ; flicker noise
+ VtoTC=-2m BetaTCe=-0.25 Xti=35 ; tempcos
.ends SJDP120R085
Joined 2003
latest iteration of LuDEF sim , much closer to pure DEFiSIT ideal ..... no source degeneration for IRFP9240 , while entire combo consisted of LU. it's source resistor and IRFP240 cascode should be considered as poor man's SIT substitution
hey , it gnawed just right on me ...... one can try even poorer man's SIT Substitution (as fast & furious taste of Real McKay) ..... using verbatim M2 circuit , but connecting upper mosfet with Shade thingie (1K+10K) ........ will try that sim pronto :clown:
mild and slow thump (under 400mV) during startup , most probably even lowered due to action of (commonly used in Papamps) NTC softstart
There is no AC signal on the drain of the MOSFET (the drain is grounded AC wise through the PSU) so there can be no feedback that way (nothing to feed back, just a static DC bias conditiion).
The last paragraph on that page speaks only about cathode degeneration as the form of feedback that lowers the distortion and it's irrelevant from the "turn penthode into triode" point of view.
