Questions about amp camp amp and linear power supply
I'm in the process of building some open baffle speakers with a 12" coaxial with 97db sensitivity and 1" compression driver with 109db sensitivity. Active crossovers and eq will be done with a miniDSP 4x10HD. I'm really interested in building my own amplifiers, but I don't have any experience with it. I am tempted to try the amp camp amp. Will 6 watts be enough for midrange and tweeter with that high sensitivity and in a 25 square meter room?
I'll also be using 15" woofers for 150Hz and down, but I have amps for those.
I was also wondering if anyone has heard the ACA with both linear power supply and with the laptop power supply? If I'm going to build this, I think I want to try a linear power supply if there is much to gain in sound quality from doing this. Is there any build guides for linear power supply for 240V AC?
Thanks!
With speakers this sensitive, you won't need 6 Watt. With 1 Watt you can blow out your windows :D
But you will need a very, very quiet amp. I don't know the ACA, but I do know the Aleph (comparable in a couple of ways). This Aleph is not that critical.
I'm always fond of a standard CRC. About 10mf per ampere and burn a few percent of the voltage in the resistor. If you can get everything at surplus prices, such a linear supply is also cheap.
Hi Jonse, there is a lot of info the find on the firstwatt.com website. Do you want a standard capacitor type? Take a look on the Zen. Do you want it regulated? Take a look at Zen Variations 3.
You want CRC? Most of the normal Firstwatt and Pass amps use this.
Joined 2000
In normal rooms 6w this is plenty for tweeter and mid, but in a 25m^2 room, I'm not too sure. I use the ACA on 86db efficient speakers in a small area, say, 5m x 15m area and it's fine. Then again I don't need it to be ultra loud.
I built the ACA with linear ~19v supply and it sound just great. I can't say enough good things about it.
I have not heard the ACA with a SMPS. I'm sure if you use a well made SMPS, it will sound great too.
ACA illustrated build guide
Vince
Joined 2000
Some pics.
Some pics.
Great build, looks good! How does the sound quality compare to a integrated/power amps you've had before? Nelson Pass mentions that this amp isn't designed for the best possible sound quality but for easy build. So I'm wondering if I'm better off just buying a cheap power amp like the Topping TP60, Dayton Audio APA150 or something similar.
I see now that the plans for ACA 1.1 is going to be released soon, so I may just wait and build that one instead.
Joined 2000
I have a class D amp and chip amp. Fun for 1 hour, then they get irritating. The ACA is not only an amp for builders that need training wheels, but also an elegant amp that has an interesting output stage and holds its own again anything. I would think a person who likes tube amps would also like the ACA. Very smooth. Somehow has amazing bass.
The aca 1.1 is just a slightly upgraded aca. R15 was added and R12 was changed. That info is in the thread.
You could wait for aca 2.0. That's a bit more differrnt, with more power capability, I believe.
I just paid $18 US each for 6.5A Mean Well smps.
At least Meanwell is a known Chinese brand.
I semi recently bought 2... 25 Volters for significantly Mo' $ than that... Both subsequently / soon failed, one damaging an amp in process .
Apparently SMPS failures are more common than generally acknowledged.
Dunno .. but certainly 2 was enough for me
Only SMPs that seem trustworthy.. in My mind... are the laptop bricks.
Until well proven otherwise.. I'm only willing to trust to a Transformer.
Joined 2000
They Meant Well...;)
I have access to a lot of unused bricks, especially 19.5v 5A and up. 24v are a little rare at work. Don't know why I pulled the trigger on the Mean Wells, might have to do with keeping everything inside the case. Don't know if there will be much radiation from the supplies. Hope not.
Ok, a question for the experts (or at least those with more experience than I):
I've got an ACA (from BA17) running on a 24v 8A switching power supply. I can't hear any hum or ripple, and all the scope shows is a neat little triangle wave at 50kHz (with the expected MHz ring), and a listed 82mV P-P max measurement and an averaged 13mV RMS. Is that quiet enough, or should I be unsatisfied with any visible/measurable ripple?
Or is that a little over the top?
