Help CCS for 1.33mA
LND150 is for sure better for low currents. However, you could try this:
Thank you Sheldon, could you post schematic or link to schematic?
The schematic is on the data sheet I linked (Id vs Rsource). You can see that the temp coefficient is stable about 0.6ma current. So parallel two FETs with a common source resistor. Source resistor value will be 1/2 of that for a single FET. Resistor value would be about 500R. Start with a trimmer, then replace with a fixed value if you like.
Yes, as I said in my original reply, one can select parts with high enough Idss, so that one will suffice. Depends on the power handling limits of the part, whether or not parallel devices are required. Merlin didn't specify voltage and I'll leave it up to him to do the analysis. Can always cascade too if you need higher dynamic impedance. Parallel parts in the top half, single part on the bottom. Trade-offs, as always.
