Nakamichi PA 5 II Resistor
Hi i have a problem with a channel. I found only a R on emettitor burned Only R (i Think autooscillation), manual service tell me replace with a fail safe (1 ohm 2w). I have replace it with a metalized flameproof, make low voltage test, and all ok, so i have assembled and i’ll read perfect bias (40mv) for 20 minutes then dropped to 1,5mV and I find all the resistors that measure even 1.8/2.5 ohm (1 ohm) and some interrupted and now There Is only one final transistor burned.
Everything is perfect. In attachment there is PA 7 but is same project
What is the problem? Metallized R is Not ok??
Thank you
Nothing to do. I change R with wirewound and one final transistor. power on and no error, relay close and start, but if i search to set 3,9V on TP3, R of check burn and smoke... i just check every diode transistor R Cap and it’s all right.
Is possible that final transistors also if good to be “burn”?
Can you help me?
