PMC MB2S CLONE
I have been using an active filter design from ESP for this purpose. You could try looking for the filters for the Wilmslow Audio Prestige range if you want an existing design, or possibly contact Volt directly, they are helpful people, they might be able to send you a schematic.
Pleased I found this thread rather than startinanother, I am going to try and work on a design influenced by the BB5 but not a clone.
Does anyone have a bandpass filter design for the Volt VM752 mid I could experiment with?
Many thanks,
Simon :)
Check it with them first, I haven't done a Volt dome but I have done PMC and they look spookily similar, they even fit into the same panel cutouts and the bolts are in the same place. Might be worth checking that you can actually buy the domes too. I was amazed at how they self-align when you put them together.
I have an active system using these PMC domes with Volt Radial bass and high-end Scanspeak tweeters, the realism of the sound produced is jaw-dropping.
Thanks for that good to know that the dome in the Volt is user changeable, could be a dealmaker for me!!
Volt Radial RV3143 12" in bass reflex although I would like to get hold of something mimicking the PMC ATL at some point. One other thing about these drivers is they will go VERY LOUD without changing sound quality, if that is of any interest to you. Also they are "real" rather than "nice hifi" probably what hifi people call "too analytical" - to me they are just realistic. I think they are better active too, although it does add some complication.
Will do thank you! Quick question if I may, what bass driver are you using and what loading method?
Founder of XSA-Labs
Joined 2012
http://www.diyaudio.com/forums/multi-way/281778-low-cost-pmc-inspired-tl-monitor-dc130a-dc28f.html
Hi Simon,
I went for active filtering with an DSP which gives you max flexibility. I hadn't decided on the tweeter yet, with the DSP I could always modify cross point and type of filter (12dB/Oct or 24dB/Oct and LR or other), so I had the opportunity to try different tweeters on various X-points and filter characteristics. In the passed I had Synthese 2 (passive), K+H O300 (active) and Focal SM9 (active). I was never really happy with the result so I tried many other professional monitors but never liked them. I'm pleased with the current config..
