Do you mean "select internet radio" in LMS?
I assume u are running the Squeezelite renderer in moOde.
-Tim
Yes I am trying to open internet Radio stations in LMS. I also thought that moOde had it's own internet stations. How do I go about accessing these stations.
Yes I am running the Squeezelite renderer in moOde.
JB Radio 2 has changed its 320kbps stream url to
http://184.75.223.178/proxy/sdsyygqt?mp=/mp3-320
Phil
Phil
Dunno about the LMS issue but moOde's radio station feature is only accessible via moOde WebUI.
-Tim
Phil
Hi Phil,
I'll add to the TODO list.
-Tim
I would like to modify the UI of my Moode 3.8.4 as shown in the attachment.
I use the official Raspberry Display and need a little bit more space.
So I would like to move the Play / Stop menu to the titlebar as on the browse and library page and hide the whole volume stuff because i dont't use the volume control.
But I have no clue in web programming.
Any hints ?
Michael
I change the zoom on my official rpi display and the standard interface fits fine. About 75% zoom works.
see Tims guide in post #10023Using moOde password protected on workplace WLAN's seems like a pretty narrow usage scenario so unless I get more requests for it, adding pwd protect would be up to user.
..snip....
I think this resolves your problem: Shairport-sync Name * Issue #510 * mikebrady/shairport-sync * GitHub
But... I would like to have a password option, both for Moode config and for airport.
You can remove the link to the config pages by editing the link out of the main HTML page, but it would be nice if it was available as an option in the configure>general sub-page.
Maybe an option for ver.4.01?
... Thank you for the guide.
But yes workplace wlan is quite narrow. Thou I think the password option is not just for workplaces but also for other environments.
Thank you Tim & Zootalaws.
This was easier than I thought, and works like a charm.
For those of you running with raspotify as well, remember to disable discovery mode - if you fail to do this you'll eventually end up confused
I tried this first, but my eyes are old and my fingers fat
Hi Guys!
Have sadly recognized, that the wonderful JB Radio 2 isn't working anymore.
On Archphile I was able to implement 2 more streaming options for JB Radio 2, one of them a 16bit 192khz flac stream, that sounds excellent;-).
But with MoOde I'm not able to create the station playable.
The flac stream for JB Radio 2:
http://209.126.66.166:10999/flac.m3u
There is a still active mp3 320K channel existing-
but same as with the URL above- not playable after creating the station.
With Archphile both flac and mp3 versions are playing.
Maybe someone has an idea how to store both URL's successfully under 'Radio'
Thanx and greetingz
Robert
Thanx and greetingz
Robert
Hi Guys!
Thanx and greetingz
Robert
See a few posts above for a working 320Kbps mp3 stream.
Try pasting the url in the flac.m3u into the Moode config for the station.
Phil
-Tim
Is the moOde web UI only accessible through a pc or can I use my andriod phone (Samsung) to access moOde via wifi. I have tried using my phone with both IP address and also name.local of the device but it has been a no go.
Name.local won't work on Android but IP address should be OK.
I have only made this URL play in VLC. I have tried the Android TuneIn app (there is a facility to add an external URL) and that does not work.
I have been informed from another forum that the IOS TuneIn app, will however, play the URL but I can't test that at the moment.
Ronnie
Ronnie
The url from the m3u file plays in Moode.
Phil
Oh, thanks for that.
I only found out about the flac stream maybe 12 weeks or so ago, I can't remember trying it in Moode (I knew about the 320 stream, which I use in LMS).
I'll maybe try a fresh MoOde tomorrow, as I tend to mostly stream with LMS (FIP is rapidly becoming a firm favourite ).
Ronnie
Ronnie
To late to edit my post but just wanted to say that the Tunein URL that I have been using for several weeks in LMS is still working fine.
ronnie
URL: http://opml.radiotime.com/Tune.ashx?id=s269312&partnerId=16&username=*****
ronnie
Moode Audio not showing as an Airplay device on any IOS 11 device I am using the current version.
Have you turned airplay on?
One of the more rock-solid features, it works on all our Apple devices, going right back to when Tim first implemented it.
wifi signal is enough?
metal case with Pi3 integrated wifi could cause a problem
metal case 5mb/s enough for DSD and some dropouts on PCM
wifi dongle 26m/s or more enough for DSD
- PC Based
- Moode Audio Player for Raspberry Pi
