Beyond the Ariel
After some speculation and above looks maybe too good to be true for acoustic domain especially if they comp filter reflections sits there, therefor find first below where we can see raw FDW filtered response that was used above times reverse correction curve, second is same raw but non FDW filtered and the next three are result when this one is times reverse correction curve, and overall think correction result is still pretty good.
It looks being in yours too just harder to see because of crude time scale, below should help with a zero time line edited white then follow performance of black dotted peak energy time which very weird show frq 4kHz and up will happen before real time, the one at right better follow book for minimum phase domain.
It looks like the actual start of the IR is the peak before the one that hits 100%. REW aligns the highest peak and takes that as t=0.
Joined 2008
If radiation is like a wifi symbol the waveguide will do its job, which (besides directivity control) is to respect the source (keeping it the true source). If the horn isn't the right shape, if the driver wavefront isn't right or matched to the horn, if sound diffracts in a bad way then energy will be spatially lost with possibly complex undesirable characteristics.
Joined 2008
I'm glad you like my humour. This information is interspersed in this and other key threads, such as the Geddes on waveguides thread and is quite involved. But if you want an example, OK..
A waveguide wall is like a mirror. If the wavefront travelling along it is normal to it then it effectively holds it the same as how what would be there in an equivalent full space radiation. If it is not then the reflection will deviate and have an effective source that is in a different location in space, such as direction and timing, and could be heard as such and could also continue to become a room wall reflection. Once the energy goes wayward it is no simple task to stop it so it needs to be kept right from the start, and typically for as long as practical.
Respecting the source as I alluded to above, is in my opinion key to getting the most out of a waveguide system. Using the oblate spheroidal shape is the key to doing this when beginning with a typical compression driver with a round planar wavefront.
Administrator
Joined 2004
All the O.S waveguides I've seen in person or in print are just a shallow conical horn with better throat. In this case a short curved throat with that particular profile.
The easing of the flair at the throat does seem an improvement over abruptness of pure conical.
What I am currently wondering about is the discussion culture.
We were in an brilliant exchange of different experiences/measurements/analysis of impulse responses, mainly at HF where any horn is probably more or less of minor relevance. We were not at the point what is the best horn/waveguide.
I would assume that many of us would greatly appreciate if the supporters of OS waveguides deliver comparable measurements or maybe better drivers.
POOH crititzied the Radians but he delivered measurements we were able to discuss about and compare them. I really appreciate his kind of discussion.
I would suggest to do all measurements about 1m or 2m from the horn mouth, so all sound waves interactions would be visible on the measurements. It is very, very rare circumstances where a listener is several centimeters from the horn mouth.
regards
ivica
