About possible Babelfish J interest
Official Court Jester
Joined 2003
however .... just chill out
when I was a youngster (somewhere in time of Dodo) , i was so exalted , while concocting my first PP tube amp ...... finally , spent two days searching why I had no sound in speakers ;
every point passed DC measurements , had no scope , had no gene (except finger)
chased more than one tail ...... finally found systematic flaw on both monoblocks - forgot to mount half inch wires connecting (meticulously mounted) signal caps in-between phase splitter and output toobz grids
wasn't last time Mighty ZM showing all his Mightiness .......
:clown:
........ wanna hear what's happening when systematically swapping routes of pin 1 and pin 2 on XLR connections in preamp ?
everything works flawlessly , upon connecting drek to source and power amp , then .......
:rofl:
Founder of XSA-Labs
Joined 2012
I have a 400va 18vac toroidal trafo feeding parallel connected CRC PSU's at the AC input to the diode bridges. The CRC PSU is the one from here:
CRC Power Supply (Class A amplifier)
635473d1505455815-crc-power-supply-class-amplifier-crc-class-psu-build-jpg
The ground after the second capacitor bank is connected to the clean side of a GLB (8R, 2 diodes, 100nF). The dirty side of GLB is connected to chassis and earth ground.
Each PSU has +/-24v and GND (to the common clean GND pin) to the amp modules.
I am away from computer so can't draw schematic yet.
Joined 2003
considering that you have common secondaries for both PSU pcbs , you must establish common GND for both channels
that means - fat wire connecting main GND points of two pcbs , then main GND preferably being on exact middle of that fat wire
then , depending how you made overal grounding routes , maybe you'll need fat wire connecting main GND points of two channel pcbs
maybe shortest way of curing it is - that fat wire between two channel pcbs , without first mentioned
for least problems - either go with proper dual mono ( separate xformers or at least separate secondaries for each channel PSU) or usual common PSU for both channels
you have worst possible combo - common xformer to separate rectifiers and cap banks
Founder of XSA-Labs
Joined 2012
I think I will order a pair of 18VAC trafo's and start over. Connecting a 12ga solid copper ground bus between the PSU's and tying the amps at midpoint actually made the problem worse! So, I am at a loss. When using SMPS, I don't seem to have the cursed ground loop chasing my tail problem. So, the amp is off the bench and will have to wait for a day when I have the dual trafo's or maybe switch to SMPS.
Joined 2003
there are several places where you can try to establish common path between two grounds , and which one (or even two ) will work best is thing to try
-only between two channel pcbs main GND points
-between two output GND points of PSU pcbs
-between GNDs where they first established (sort of) at first C in CRC
anyway - as I wrote previously - worst solution is when you have half of two approaches ( dual mono vs. not so dual :clown: ) ....... almost situation as being little pregnant :)
you can also try to include series resistor of 10-22R in one channel's input GND
then to try NTC from GND to case , or directly GND to case
Founder of XSA-Labs
Joined 2012
My dual Antek AS1218 toroidal trafo's arrived yesterday. Finally had a chance to install them into a dual PSU monoblock setup with the CRC's. The only common ground point between the two amps is now a ground from the second C in the CRC (where the amp power cables are connected) to a single "clean" ground point on the ground loop breaker (GLB). The other side of the GLB (a 8R resistor with two 10A10 diodes and a 100nF 250v film cap all in parallel), connects to chassis ground and earth ground. Running at 1.20amp bias and dc offset is about 10mV, still stabilizing. The output noise with inputs shorted is now 0.9mVac (not 0.1mVac as before), but this figure does not change when I plug the input into a DAC. Music is playing now and first few tracks on my XKi speaker fitted with a Tang Band W5-2143 sounds really good. Nice bass, articulate and clear while deep. Mids and highs sound very clear and fluid. Will listen more now. Here is a photo of the temp setup before I drill holes and hard mount stuff. It all fits nicely.
Thanks ZenMod, for the nice Babelfishing effort, the amp sounds really good.
:cheers:
attachment.php
Founder of XSA-Labs
Joined 2012
I just put the Babelfish J amp up to my measurement rig (8ohm 25w resistor and Focusrite 2i4) and am getting a rather high 0.21% THD at 2.83vrms into 8ohms. Is this normal - and predicted by simulation, or perhaps I have something off in my amp? One thing that is nice to see is that my linear PSU appears to be working very well now with no more "forest of noise" like I had before when running the single trafo on the M2. Here is the FFT for left and right channels driving 2.83v rms into 8ohm resistive load. Voltage on load read-out with 2k/22k voltage divider.
Left Ch:
attachment.php
Rt Ch:
attachment.php
