Dear Wayne,
What do you think, it can be used in balanced or bridged mode?
I mean one board for left channel and one for right channel.
If it can be possible, then I send you the money right now for another PCB.
Thank you in advance,
Gyuri
I don't see any reason you couldn't do this just feed each board a balanced signal.
Hello Patrick,
do you use in your F5-HA main filter with CMC?
My Schurter main filter includes an 2x4mH CMC; main filter checked ok (removing middle point connexion of toroidal 230v side) with 2A SB fuse.
As always, I think something really stupid is going on (perhaps wrong fuse? Ordered new ones).
JP
JP
I have two questions:
Are there any penalties (soundwise) if I would be used Fairchild FQP3N30/FQP3P20 pairs instead of Toshiba 2SK2013/2SJ313 pairs?
Need I change to something in the schematic?
Regards:
Gyuri
Should be fine - no change to the schematics. No idea about the sound though.
Thanks guys,
I asked because I have two pairs of 2SK2013/2SJ313 for one PCB, and virtually countless pairs of FQP3N30/FQP3P20.
Then I will order missing parts for two boards.
(Wayne, have you got the money for second board?)
Another thought, can I raise power supply voltages?
Because if I can understand it well, with Fairchild pairs output voltage swing will be lower. Not if it count if I only drive headphones with it, perhaps I would drive my balanced F4 with it.
Any suggestion in this regard?
- New PassDIY Headphone Amp (now available)
