Active subwoofer and satellite crossover
Active subwoofer and satellite filter boards
Prototype for an active crossover. Will be used in a pa subwoofer with big class d amplifier.
Features are:
Balanced in
Adjustable lowpass 50-250Hz
Volume control sub channel
Phase invert switch
Balanced out sat channel fixed level and highpass 120Hz.
I will also make a board for active satellite with following features:
Balanced in with mic/line switch and volume control
Unbalanced line in with volume control
Tone control bass/treble
Subwoofer amplifier will be something like this:
https://m.aliexpress.com/s/item/325...ubject=32562266578&shortkey=ZJZRv6V3#autostay
looks like you are adopting a B2 (Butterworth 2pole) filter.
Bass channel: change the 220nF to 200nF to get the correct roll off.
Mid/Treble channel: why an extra gain of 3.2times (+10.1dB)?
You have differential interference filtering, but no common mode filtering.
Add a couple of pF NPO ceramic from pins 2&3 to enclosure at the XLR socket. You can increase the effectiveness of these filters by preceding them with 100r or similar.
I don't see any advantage in using the 3k3 impedance reducer at the input.
Note that the two GND symbols at the input are Pin1 and go to enclosure.
All the later GND symbols are audio ground and these do not go to the enclosure.
Except the balanced output which should have another Pin1 connection to the enclosure.
This balanced output shows GND to - out. This is wrong !
I recommend you look at adopting AC coupling either at your balanced outputs, or at your balanced inputs.
Thanks for your reply.
I have made some changes to the schematics.
I have added capacitors on all inputs and removed the 3K3 resistor.
The circuit is noise free, so I'm not sure if the extra filtering on the input is needed.
Changed the 220n to 2x100n for the lowpass filter.
Changed the 22K resistors on the mid/high balanced input to 10K for less gain,
Today I will test version 2 of the subwoofer board.
I added a selectable highpass (currently resistors are set for 25Hz and 40Hz, but can be changed according needs)
Also I added 2 transistors in the powersupply circuit so the board can run directly from amplifier voltage rails up to 80V (small clipon heatsinks needed). Now testing with +40V/-40V rail voltages, highest as my lab powersupply will go :)
Trying to fit the circuits on 5cmx10cm boards as this size is very cheap in china for dual sided PCB.
