Crossing an 8" at 1600kHz
A good 8" can readily do that for you, and it makes the compression driver/horn solution a whole lot easier (it's a stretch to run many of these CD horns at 1khz). If you wanted to go with a highly directional system, the selenium hm17-25 is a great sounding inexpensive 60x40 option that's very comfortable with a 2-2.2khz XO.
Thanks everyone! Below are the components I plan to use - pretty conventional but I think it will do the trick in the 42L box I have. I am certain the crossover will need adjusting with an L-pad and some additional caps. I've had great results with this tweeter/horn combination crossed to a 10" on an open baffle and I am hoping to get similar sound.
I think the crossover will work fine but wanted to know if crossing this low might create other issues. Typically I see 8" systems crossing above 2kHz. I come from a full-range driver background and hope to avoid any foolish mistakes.
Pyle PDS442 compression driver:
https://www.parts-express.com/pyle-pds442-1-titanium-horn-driver-1-3-8-18-tpi--292-2510
Selenium aluminum horn:
https://www.parts-express.com/selenium-hm25-25-1-exponential-horn-90x60-1-3-8-18-tpi--264-312
Dayton Audio 8" pro woofer:
https://www.parts-express.com/dayton-audio-pa200-8-8-pro-woofer-speaker--295-025
Eminence pre-assembled crossover:
https://www.parts-express.com/eminence-pxb2-1k6-2-way-speaker-crossover-board-1600-hz--290-634
At a glance, the 8" response is near enough 'setting' on the baffle at ~160 deg [180 deg in theory]/1600 Hz whereas the horn is around 45 deg/horizontal, so has an off axis response similar to a alum. dome 'FR' driver, requiring running the horn 'hot' with a HF bypass cap and listening off axis like with a Lowther or similar.
GM
Eminence's 1K6 xover parts values: Lowpass = 1.18/10uF - -Highpass 8uF~0.28mH- 22uF (I only measured the two unmarked inductors - all caps are labeled) - someone good with a simulator could see how this generic network blends with components of interest.
fwiw I'd trust an ASD1001 more than a Pyle. Hwathorne ran ASD1001 low in their original Silver Iris 15cx
how about "this" PRV waveguide? - its like a 1/4" thick or more casting
https://www.parts-express.com/prv-a...iptical-tractrix-waveguide-2-3-bolt--294-2890
42l is pretty big
