Speaker Protection Kit for under $5
Do these little guys protect against turn off thump? I have some compression drivers I'd rather not destroy ;)
delay to ON and instant OFF isolates the speaker before tha amplifier starts to shut down.
Instant OFF requires detection of the AC waveform and that loss of AC triggers the circuit.
This can be used for input mute of a Power Amplifier and can also be used as an output mute of a Source.
You should use very low Z relays without any capacitor after the rectifier.
PS : others should try to plug and unplug several times their boards to see what happened :D
You are reading but not assessing the content. Read and understand and discard the chaff.
Add the time to detect the loss of AC waveform. That amounts to ~10ms.
Add on the electronic delay, maybe another ms.
Add on the relay drop out time, maybe another 2 to 5ms
That totals 12ms to 18ms.
Waiting for the DC on the power supply to sag enough to allow the relay to drop out could take 10000ms, or if you arrange for a very low charge storage one could get down to maybe 1000ms
Too slow, by more than a decade and could be three decades slower to isolate.
Here is the simulation.
15V transformer, 220uF, 12V 3 terminal regulator. The relays are simulated as 180ohm load (2xOmron G2RL2 12V coil).
Sine wave runs up to 2s. The output voltage falls to 1V in 70ms(blue line) . Relay must release at 1,2V.
Sajti
