MTM with TC9fd
music soothes the savage beast
Joined 2004
here is just a suggestion, an alternative to Nola Brio Trio, or Mini Karlsonator with Dual TC9fd-18-08...
I built NOLA Brio Trio, just in foam core, and just for fun. While it played ok with the sub, ultimately, I did not like two things:
first, two tweeters in a sense, as one is run fullrange, one with high pass, still, both project heights...I do not like that
second, while TC9fd is performing well in midrange area, and may be extended to the heights, when it comes to of axis, it starts beaming terribly from about 5kHz. Just look at of axis response.
So I converted Nola Brio Trio to typical MTM with small Dayton dome. Quick and dirty crossover, measurement and listening lead to an amazing sounding neutral speaker. I have not saved the measurements, but it was exceptionally flat. I may redo the measurements once I paint the foam core.
If you need HiFi bookshelf, built this one...
If you run it from 150Hz with sub, you will love it.
Joined 2004
How are you not getting huge comb filtering with such a small MTM? Wouldn't it be prudent to re-structure it as a 2.5-way where you bring in the second TC9 below the 1/4 wavelength spacing?
I will post some measurements...I see non what you are saying.
Feel free to make my version, measure it, then convert it to 2.5 way, re-measure it, and post the results. Should be interesting.
Joined 2004
Just rambling here...
I briefly looked at Holm data and noticed well behaved phase response. Flat accross the crossover point. Most likely great contribution to the natural coherent sound. Amazing speakers considering the price and construction.
Do not forget to switch tweeters polarity, otherwise you geat nasty dip at 4.5 kHz and phase is a mess.
Other contributing factor to great sound is open back and high pass filter from 150Hz.
Not sure how it would behave if you run it fullrange (not recommended).
Other minor downside is power handling. This is not a party speaker.
Otherwise this is a great speaker to build just for fun. Reward guarantied.
