After the great success the first version Quanghao opens a new group buy to produce a new series of DAC ES9038PRO:
[URL="http://quanghao.com/product-es9038-pd94325.html"]10th birthday anniversary[/URL]
Es9038 PRO DAC - Design by Andrea Ciuffoli-Quang Hao
Output: Stereo balanced output impedance: 202 / 4 = 50 ohm
DC-ouput: +1.65VDC.
Output impedance: 100 Ohm.
Output: 2-Channel (stereo) outputs can be used in current-output or voltage-output mode
(depends on output stage used)
Input: 4 inputs:
1. USB -match with Amanero USB (not included). Have pin I2C for other USB
2. Spdif
3. AES/EBU.
4. Optical
Digiltal supply:
1.2V core: LT3042
3.3V oscillator: LT3042
3.3V digital: LT3042
3.3V Top-botton chip
3.3V USB: LT3042 (If you not like us 3.3v from Computer for USB)
Analog supply:
1.2V analog (left and right separated): LT3042
3.3V analog (left and right separated): LT3042
5V for LCD: LT1117
5V Analog supply: LT1117
5V Digiltal supply Digiltal supply: LT1117
Controls and features:
1. Standby mode.
2. High volume display.
3. 20 x 4 LCD display.
4. Select the 4-way input and display the frequency on the LCD screen
5. Fuse protection - 220 VAC power supply / 5W
6.Turn on, off with remote control or buttons.
7. Simple and appropriate use for DAC chips: ES9038PRO, ES9028PRO.
8. Set up customizable protocols such as: volume, input as you like.
9. Select modes such as filter, frequency, left channel right.
10. Special and unique - Store settings according to your preferences:
A, Keep the big picture to the desired: lowest -100dB, largest 0dB.
B, Select and store left or right channel output - No need to reverse the output.
C, Selectable filter modes: (Pass band): 47kHz, 50kHz, 60kHz, 70kHz.
D, Option: PCM Filter Characteristics
E, Selectable filter modes: (Pass band): 47kHz, 50kHz, 60kHz, 70kHz.
F, Option: PCM Filter Characteristics: Fast, Slow Roll-Off, Apodizing, Hybrid, Brickwall.
On-board DAC ESD9038PRO includes:
1. ES9038PRO chip.
2. Clock 100MHz CCHD-575, Ultra-Low Phase Noise Crystal Oscillator.
3. All Input connecters, Amanero USB (not included)
4. All low noise Lt3042
5. LM1117
Use: it is simple and need:
1. Transformer 15VA to 25VA: 2 x 6 - 8VAC: Talema 70050 or Talema 70060 Or equivalent
2. Use LCD Control board off Andrea-quanghao for ES9038PRO, ES9028PRO
This options are available and here the new cost:
1) DAC module assembled and tested with all components:
- ES9038PRO chip,
- CCHD-575 Ultra-Low Phase Noise Crystal Oscillator: Ultra-low phase noise CMOS oscillator provides 168-dBc/Hz noise floor | Electronics EETimes
- 7 x LT3042 linear power supply regulator 1uV noise
- 5 x LT1117 linear power supply regulator.
- All input connectors
- BUT NO OUTPUT STAGE
price 400$
2) DAC controller- Encorder + 4 x 20 LCD:
see video for LCD: https://www.youtube.com/watch?v=4owu...ature=youtu.be
3) Amanero module
Please purchase from: : Amanero Technologies
4) Transformers, for the DAC: 6.5V x 2 / 15VA
price 30$ each
5) Chassie: include: weighs: 10 kg
- 1 x chassis, iron powder coated black, size: 420 x 380 x 86 mm,
- 1 x front surface silver anodized scratch: 430mm x 92mm x 10mm.
- 4 x rubber feet: 20mm high, 50mm wide
- 2 x aluminum knob 26mm x 38mm
- 1 x Plug + switch
- 20 x copper base 10 x 3 mm
- fasteners: catch the front, the back, motherboards, storage tank foam.
price 150$
Shipping by TNT:
A. The options : 1 to 3 : 60$ ( the same price)
B. The options : 1 to 4 : 75$ ( the same price)
C. The options : 5 : very heavy, calculated separately for each country.
This project is a great DAC, I want to share with you,
However, I need your help, let me do it!
The minimum required number 15 set: DAC+ Controle DAC
I started producing.
Payment: half the amount for the selection, the remaining amount of money + shipping payment before shipping.
Payment by paypal: quanghao168@yahoo.com.vn
Paypal free: 2%.
Note: Because this is a shared project, and need money to produce,
Therefore, you have paid half of the money for the project will not be allowed to get back the money - this is a mandatory provision of this buying group!
One-year warranty.
You send me back defective products and carrier billing yourself.
I return it to you and I pay for shipping to you, after you're done!
- Based on the ESS Sabre32 Reference (ES9038PRO) DAC chip
- Support 44,88,96,192,352,384KHz PCM and DSD to play SACD ISO.
- Full ground isolation from USB module
- On board reference 100MHz Crystek oscillator with a jitter of 0.5psecUltra fast oscillator buffer
DC-ouput: +1.65VDC.
Input: 4 inputs:
2. Spdif
3. AES/EBU.
4. Optical
Digiltal supply:
1.2V core: LT3042
Analog supply:
5V for LCD: LT1117
1. Standby mode.
1. ES9038PRO chip.
5. LM1117
- ES9038PRO chip,
price 400$
- 20x4 LCD
- Infrared remote command
- Remote silver
- All connectors
3) Amanero module
price 30$ each
- 1 x Plug + switch
price 150$
Shipping by TNT:
Paypal free: 2%.
One-year warranty.
Is this capable of separately controlling the volume of the left channel from the right channel? Or can the volume be bypassed? I need to separately control the left channel volume from the right channel.
You want to channel the output channel ??
It does.
Change the output as follows: R- L or L-R, (no need to invert DAC conductor)
thank and see
I like this project, just a question: if I choose options 1,2,4,5 (i dont need usb) what else do I need to complete it?...I saw pictures with an output tube stage in the older thread but it's not in the list here. Thanks!
this IV for layout now!
Balanced ouput with Tranfomer LL1684
Unbalanced converter with Tube
thanks
1: CAAD: Option, 1,2,4 and 5.
2: CAAD: Option: 1,2,3,4,5 and complete Tube output
3. gcolombo: Option: 1,2 and 3.
4. akltam Option 1
5. gcolombo: Option, 1,2,
6. Researcher: options 1,2,4,5 (i dont need usb)
7. hbit: Option 1, 2 and one pair LL1684 PCB ( L and R) (25$)
15
4. akltam Option 1
15
4. akltam Option 1
8.Tuanvq: 1,2,3
15
4. akltam Option 1
8.Tuanvq: 1,2,3
15
thanks
Hello
what is the situation for the IV:
PCB price ?
Components ?
Serge
4. akltam Option 1
8.Tuanvq: 1,2,3
9. ivigueras: option 1,2
15
4. akltam Option 1
8.Tuanvq: 1,2,3
15
DAC ES9038 PRO GR 2 ,
about 2 week later i will have all kits!
4. akltam Option 1
8.Tuanvq: 1,2,3
15. End
4. akltam Option 1
8.Tuanvq: 1,2,3
15. End
please wait me finis this layout!Hello
PCB price ?
Components ?
Serge
thanks
Group 2 Buy List
4. akltam Option 1,2,5
8.Tuanvq: 1,2,3
15. End
8.Tuanvq: 1,2,3
15. End
4. akltam Option 1
8- jpduarte- Option 5
15
Group 2 Buy List
8.Tuanvq: 1,2,3
10. jpduarte: Option 5
15. End
8.Tuanvq: 1,2,3
15. End
8.Tuanvq: 1,2,3
11. Virtuez: Option 1,2
15. End
8.Tuanvq: 1,2,3
15. End
very interesting project, is it possible to have a direct I2S-LVDS input with HDMI connector (PS audio standard) in the rear panel and possible to select this, besides all other inputs?
I dont understand why you choose Amanero USB card when there are latest products as Xmos Xcore200 chipset based cards and dsd 1024 support in native mode?
Thank you so much and soyy for my bad english.
Marcello masi - Italy
- Group Buys
- DAC ES9038 PRO GR 2
