Just another "recapping headache" thread
Ok so i got a nice little working NIKKO TRM 210 AMP for my first recap job. The circuit is simple, as its a lil 12wpc unit.
Replaced all the caps. Thought everything was goin well. Powered it up and one cap was smoking!(2200mf 63v..C669 on schematic). Noticed that it was inserted the wrong way around (im an idiot, i know).
Anyways so i just got a new cap from digikey but now i get no sound at all!
Judging from the schematic, there are no reference voltages or fuses.
How would you recommend i start troubleshooting?
I have a multimeter, signal tracer, oscilloscope, signal gen.
Thanks!!
Does the power light come on?
The only fuse I can see is mains fuse on the rear panel
I assume you changed the cap i circled in the schematic... check the voltage at the arrow it should be about 1/2 of V+
Do you have a V+?? check at the centre junction of D691
hope this helps
regards
james
I'm guessing C670, please correct me. You may have smoked the output TR's.
If C670 then check all power amp TR's in relevent channen(Q652,4, 654,6,8, 660,2).
I would expect this to take out one side only. Please share with us the cap number
Cxxx.
hope this helps
regards
james
Yes, C 669 is culprit! Im getting 0v there. However i am not sure how to determine V+.
Can anything be determined by the mains fuse?
If the light comes on, that one is in.
It's weird that you should have no sound at all, even on the other channel where I assume the cap was installed correctly. What's the voltage on the big 1000µ filter cap like (hilariously undersized btw, for a power bandwidth down to 20 Hz into 2x 8 ohms you'd need more like 3900)? I assume it should be about 40 V, +/-.
The rectifier appears to be composed of two of these 3-legged things with 2 diodes per package. Should be easy enough to test using the diode test function. These are no longer being made, but if needed it should be easy to adapt either a 4-pin bridge rectifier (needs to be 2 A, 100 V at least) or solder up some beefy rectifier diodes like 1N5401 - being very careful with orientation this time.
Methinks some PCB trace or link was acting as a fuse there. Anything on Q655 collector? (Or just measure resistance between there and the red spot when powered off, should be a direct connection.) Follow the connection, something should look toasty there.
If you do find the break, be sure to check your power transistors for hard shorts C-E before powering up. The amp has seen enough fireworks for now.
BTW, "low supply inductance" clearly wasn't a major criterion when this guy was designed. ;) Eliminating the typical sources of distortion according to Douglas Self might be an interesting learning experience.
