Audio SMPS units for sale
Up for sale 3 SMPS units with below specifications.
SMPS-500 quantity available 2
500W Continuous power 900W Peak
Unregulated Output voltage: from +-45VDC to +-90VDC
Regulated +-15VDC
110VAC or 240VAC selectable via jumper
Protection: Thermal, over current & short circuit (Permanent latch, no auto recovery) must restart SMPS and disconnect from AC line.
Maximum extra capacitance can be added to the output up to 4700uF per rail (externally)
Startup delay 2 ~ 3 seconds
PCB Size 12CM x 10.7CM
SMPS-1200 quantity available 1
Power: 1000W Continuous, 2000W PEAK.
Possible Output voltages:-
+- 53, +-64, +-78, +-93, +-104. (Unregulated)
AUX1: +-15VDC (Regulated)
AUX2: +-24VDC (Unregulated)
AUX3: +18VDC(Regulated)
ALL AUX voltages can be changed.
Separate FAN output
Maximum extra capacitance can be added to the output up to 8000uF per rail (externally)
Size: 20.5CM x 11.5CM
Protection: UVLO, Thermal, Over Current, And Short Circuit. Auto recovery every 3 seconds.
Some pictures attached, the 1200W version is still not fully populated, as I have to install the parts according to the output voltage.
Updates
Now available SMPS units with the below voltages.
SMPS-1000
+-56VDC
+-26VDC (For Class-A Amplifiers)
+-75VDC
2 Units can ship in 7 days, other units lead time is 3 weeks minimum
Price is 140US$
SMPS-600
+-39VDC
+-47VDC
+-55VDC
+-60VDC
+-63VDC
+-75VDC
Lead time is 3 weeks minimum
Price is 75US$
Shipping will be via DHL only, no other shipping options are available.
All of my SMPS units are using highest quality components, most of them from RS-Electronics (UK), and some from CHINA, And Some from JAPAN.
Any interested, please PM
Thanks!
I double that, it's not only taxes but mainly handling fees that make the purchasing of your products cost double the price. Normal post is as safe as it gets here.
Anyway, I understand your point if your country's post is not an option for you
Good luck with your products, they seem of good quality.
Thanks for the offer (I'll pm you), although you cannot do anything about DHL's policy of handling fees (70-100 euros) at least in my country. I presume that it's the case for other countries too, that's why Mouser (being that big and after complaints I assume) decided to cut a deal with some private companies and gave an option of included handling fees.
Also, share info here about your new design
samy if you meen my purchase i saved the tax from pure luck .the couriers here lead the products on purpose to the customs office in order to collect handling and clearance and they charge about 100 euro+ the taxes another 50-80 euro makes the purchase impossible.
if the go with normal post office never have issues and if they go to customs office handling and clearance is free and we pay only the taxes which most guys don't mind to pay especially with your prices which are very good.
i suggest you make a research because sometimes the greek post office cooperates with couriers from abroad.
for example from china EMS cooperate with greek post office and we have no problems there.
maybe thymios and savvas could help and ask here.
SMPS-600CD Single output version
Just released the new version of the SMPS-600,witch is the SMPS-600CD
This is the single output version of the SMPS (+ & 0 ) single voltage output, any range from 39VDC, 55VDC, 63VDC, 61VDC, 75VDC.
In addition to the +-15VDC & the +-22VDC & the FAN output. DC Sense, Standby Input.
Some pictures & a short video showing the SMPS under load, Enjoy!
https://youtu.be/eZvh-HM4mYw
