Help needed in Crosstalk calculation
Hi all
As my circuit analysis is quite disastrous, I went to Morgan Jones "Valve Amplifiers fourth edition"
He makes an analysis with two potential dividers
attachment.php
And he arrives at
Crosstalk = 20 Log {[Rsupply / (Rsupply+RL)] [Ra / (Ra+RL)]}
For a stereo pair of common cathode E88CC stages
RL=33KΩ Ra=6.6KΩ Rsupply=2Ω
Crosstalk = -100dB
For two SRPP stereo stages, my books burned out, my guess is
RL≈10mΩ (Cable) Ra≈5.2KΩ Rsupply≈10mΩ (Shunt Regulator)
Crosstalk ≈ -6dB
This result is disappointing, did I miss something?
Administrator
Joined 2004
RL is the load resistance of whatever you are driving, and as the previous poster pointed out it's not the dcr of the cable.
The equations are intended for a resistively loaded amplifier stage. RL in this case would be the equivalent resistance of the upper device in the SRPP which you might liken to a mediocre CCS. Figure out how good a CCS the upper triode is and you can determine the cross talk.
Hi Kevin, thank you very much, you may refer to something like this
attachment.php
I will redraw to understand a little bit better.
Administrator
Joined 2004
Yes, except in this case you would use rp (ra) of U2 for the calculation in the SRPP rather than external RL you've added which for the SRPP case may be ignored.
The RL Morgan Jones is referring to is just the plate load resistor in a simple common cathode amplifier and ignoring any external load.
U2 = RL in this scenario, there is no separate RL
You need to determine the value of rp at the plate of U2, this value replaces RL.
Yes Rl is the load resistance. And wouldn't the tube internal impedance be ra rather than Ra? Ra would be what is marked as "RL" in the screen cap of the Spice simulation; e.g. "plate load" resistors?
I think that I got it, roughly
Crosstalk = 20 Log {[Rsupply / (Rsupply+Ra)] [RL / (Ra+RL)]}
Edit: It should be RL=Ra assuming an infinite load, right?
attachment.php
Crosstalk = 20 Log {[Rsupply / (Rsupply+Ra)] [Ra / (Ra+Ra)]}
And now
Crosstalk ≈ -122dB
This is much better, and I do not need separate power supplies!!!
Thanks a lot to all for the help!!!
Please accept my apologies, I was so excited with the figures obtained that I lost some details, but I have a good alibi. :p:D
Just to follow my own notation I did ra=Ra, I know that it is not the proper notation but I went a little dizzy with rp, Rp, and so on, anyway both triodes are supposed equals and ra of upper triode is Ra for the bottom triode, or whatever.
BTW, my shunt regulator has less than 1mΩ of output impedance, from 10Hz to 100KHz, at least in simulations, so crosstalk figures would be even better. :cheers:
PRR
Joined 2003
Then if the thing sending crap to it has at-least 33K in it, the rail is at 0.001/33K or "huge", -150dB.
The stage getting rail crap may have 6dB-10dB PSRR, a bonus hardly worth counting.
FWIW: resistance of #20 Copper is about 10mOhm/foot, so it will need thoughtful layout to get milli-Ohm-ish rail *and ground* impedances.
Or put the boards very close each other; how that close? With your wire, about 1.5cm.
Stupid question: #20 is the thickest wire over there?
Liquid air is cheap, so superconductivity is another option...damn, valves will not be very happy, they hate liquid air. :p:D
Almost forgot the layout, I have some 6mmx4mm copper wire to reduce track resistance, once I did obtain good results that way, seriously.
I take the opportunity to ask you an indiscreet question, you joined the forum on 2003, in all those years you could not learn to use the quote button?
No offence intended, just curiosity. :)
