Salas DCG3 preamp (line & headphone)
The right one must be fake. Mine have the same lettering and orientation edge dent like the one on the left.
So does mine. I got it from Mouser.
attachment.php
Just some info for builders sourcing parts:
From mouser dn2540 came very well matched. All were between .01v of each other when measured across 6.8r resistor. Measured 1.08v for 160ma ish bias. Out of 5 devices they measured between 1.07 and 1.08v with 6.8r resistor. Nice.
Bc560 required about a dozen devices to get 4 with a hfe match within 5%.
I have not tested the bf256b. Will probably do that when it's in the circuit and adjust resistor values accordingly.
Here is some in progress pics. The case is too small, I know. Psu is lm317/337 followed by a cap multiplier that will sit on the sink opposite of the amp board.
Iam getting +17.6v and -17.8v out of my lm317/337 and cap multiplier when unloaded. Too high or just about perfect?
diyAudio Chief Moderator
Joined 2002
Salas, does the harmonic picture change as the gain/feedback is changed? I think the pics of FFT you posted on the first page are with the standard gain of 10. Will there be any change to the sound if I changed the gain to 6?
Thanks. nash
Those were for 10dB gain yes (3x). I have checked in the simulator the range 2x to 6x and it does not show significant FFT changes. I have also listened to a build that went from 3x to 4x that did not seem to detectably differentiate in tone.
