No convection path for resistors, obstructed by boards.
Its always something to keep in mind. The other thing is also to keep resistors spaced a few mm away from the board.
...unless you design for huge accelerations and vibrations. ;-)
Design of a stuff for military is quite tricky!
K8011 new mono blocks
more pics
more pics
last batch of pics
last batch of pics
R-L riaa? what chokes do you use? Is it standard schematic with 600R filters?RIAA preamplifier adjusted r-l. with separate power supply. to reduce interference.
Very good ! And wood with shiny lacquer looks even better http://www.6moons.com/audioreviews/tenor/hero_intro.jpg
My new Project PP KT88 - 2 x 30 W, 10-50000 Hz with clear and the same form amplitude +- 0 dB. 6N1P is FI, preamp 6J5P Russia on the PCB /China town for 4 $ stereo 6J1 Valve Pre-amp Dual Channel Tube Preamp Preamplifier Board / PCB new hot | eBay inside. I changed to 6J5P-the same legs and mode and put in pentode mode, adding R and C in second grid.
Hey . Moderators are not welcome technical descriptions in this topic. so please, or private message, or here http://www.diyaudio.com/forums/tubes-valves/302064-male42-riaa-preamp-discussion.html. thanks
Hello ... because as the title says this is a gallery section just for a pictures and a few comments etc
But we have (not this one) endless examples of people entering comments that have nothing to do with the original post.
Then we have post after post with numerous threads. .at this point the gallery section stops becoming a gallery section.
In this instance I agree with the moderators, a few comments is fine in my opinion
Joined 2009
Jamesfeline - superb build !
many thanks ....
- Tubes / Valves
- Photo Gallery
