Thanks for the tip, actually they are intended for PP monoblock but I'm still looking for a good schema to base on. I already have the OPT and Power Trafo with 1kv B+.
Pentode driver, and a resistor between anodes, choose for taste. That's it.
pyramid drive?
pyramid drive?
Pyramid is PP. I used the same principle in Gubernator - 13 and Gubernator - 71 amps. Much simpler, less power, but SE amp with 813 or GK-71 consumes much more than PP Pyramid with GU-50 tubes designed for mobile equipment.
Sodacose: very nice.
Here's my attempt at a tube build. I's a Muffsy BSTRD. I'm not into tubes, but I had to build the bstrd as I have built all the muffsy phono stages
I planned to run it with bare pcb for testing, then I found an old dtv decoder that I could use for chassis. Here's the result. It's not a looker, but it sounds interesting.
Thank you! That BSTRD looks like a nice little circuit, too. Nice job on the scavenged case
Here is my 12AX7/6SL7/6SN7/6AS7G pp triode amplifier. about 12w/ch.
With tone controls.
Not fully finished yet. (mark lamps and wood side panels needed)
And there is my second amplifier set. Separate pre /power amp.
Pre has 6N2P/6N6P with tone controls + 40hz 18db/oct sub out. And tube regulated power supply.
power amp has 6F12P/KT88 80w/ch
And the last is shown in the background in monoamp, that drives the subs.
Same type... 6F12P/KT88
in the foreground is shown 6as7g test bench
a big thank for the advice Artosalo
With tone controls.
excellent! very very niceHere is my 12AX7/6SL7/6SN7/6AS7G pp triode amplifier. about 12w/ch.
With tone controls.
Cheers
J.
With tone controls.
Is it an OTL amplifier?
my last build ... "sweetLANA" 6AS7G & ECC83 OTL Headphone Amp
power supply
controlboard
together with my Rasberry pi Music Player:
power supply
controlboard
EL 84 monoblocks - Eico and Fisher inspired, but more attention applied to th PSU.
Push pull? What is the power output?
No. OPT:s are inside.
Toroidy TTG-6AS7PP from poland.
- Tubes / Valves
- Photo Gallery
