Sure Electronics AA-AB32313 2x400
I make measurements Sure Electronics AA-AB32313.
All measurements are made at 10 watts of power and a load of 3.9 ohm.
The right channel (bottom) - loopback soundcard.
Thanks!
The fifth harmonic distortion appears to be a little on the high side, can you see anything else that is not as expected based on the specs?
Is there any way you can repeat the measurements with a 8-ohm load?
They all looks similar (tripath + STA516B(E)). I ordered 2 AA-AB31321 monoblocks, and I think it has parallel BTL output. There are few things I don't understand. AA-AB31321 is rated 800W@1.5 ohm, so it's 400W@3ohm ,200W@8 ohm...etc. However, there is AA-AB31315 which also rated 400W@3ohm. If they are all STA-516BE based, what would be the difference? The 2nd thing is the supply voltage. The customer support told me over voltage will burn the amp., e.g 40V->50V. The STA-516BE has maximum voltage of 65V and up to 60V is recommended. I can't see why 50V will burn the amp, and they refused to answer more technical questions I asked. Weird...
If you look at the PCB pictures below the thermal images, AA-AB31321 appears to be a configuration with two output ICs (STA516BE?) whereas AA-AB31315 appears to have a single output IC. In order to be able to drive 800W into 1.5-ohms, you would probably need 2 STA516BEs in parallel. Not sure about the output driver IC in the second configuration, since STA516BE data sheet states 400w into 2-ohms at 52V whereas the Sure AA-AB31315data sheet states 400W into 3-ohms at 44V. I don't know of any updates to STA516BE, does another vendor make a similar device with higher output power capability?
AA-AB31321: http://store3.sure-electronics.com/media/wysiwyg/AA-AB31321_5.jpg
AA-AB31315: http://store3.sure-electronics.com/media/wysiwyg/AA-AB31315_5.jpg
I think I made a mistake in the measurement.
For measuring amplifier in BTL mode I used this divider.
Do you think this schematic is correct?
Thanks. I see the difference now. AA-AB31321 does have 2 STA-516BEs working in parallel. Now I wonder the difference between this AA-AB31321 (800W) and AA-AB31392 (1000W). It seems they just increase the recommended supply voltage which I think the AA-AB31321 should also work on 50V VCC.
I made measurements at 10 watts. The dependence on the power supply type is minimal. Recent measurements are made with a linear power supply of 45V from the amplifier NAD 326bee.
I was just wondering how much the supply voltage matters. The allowed range in the data sheet is quite large but I read somewhere that it "sounds" better with the voltage at the upper end.
