100W Ultimate Fidelity Amplifier
A40 Questions
I have a nice chassis and PSU parts that I would like to use (if possible) to build an A40.
The 1200va toroids I have are 60-0-60, which gives me ~80v DC rails after rectification and CLCRC filtering. Is there anyway to use this to power an A40?
Next, has anyone done a dual mono setup (layout and pcbs) for this amp?
Thanks for your time,
Donovan
Donovan
Hi Donovan,
I believe +-80V is too high for the A40. Yo may need to look at one of Mile's class H amps. I'm not sure if the A40 could be modified to handle more output transistors. That might be a possibility. My A40 uses 63V caps so +-60V is about all I can go. Even that will be working hard with a 4 ohm load. Mile did design a PSU that is adjustable so that also might be a solution.
I alredy save this file,but after extracted i only see PSU file no another file.
What's the problem sir?
You need Sprint Layout software ,then look on the bottom left.Switch between all.
Donovan
Use Regulated PSU for Amps with 4 pairs of outputs, output voltage can be set from +/-55V to +/-90V.
Hi Guys,
The sprint file I posted had an error in the 18V shunt. I have corrected it and am sharing the corrected file below. If you want you can just correct it in you file or download the new zip file.
Thanks, Terry
  • P30-TB3-MM3.zip
