V6 amplifier
this project was started about 3months ago, to develop small sized amplifier, with high quality, and 120-140W/8ohms power.
Schematic attached.
Sajti
Schematic attached.
Sajti
Very nice , a current mirrored cascoded VAS like my IC(eyesee) input module.
Run by a CFA front end.
The triple worries me , either decouple the driver/pre (or just the pre) with
a 4R-10R + 22u/.02uf R/C. Also make sure the driver/pre are stellar in the ft
spec ( 100mhz+) ...fast- fast !! outputs just the standard 20-45mhz variety.
Edit - I notice your passive DC blocking at the (-) CFA node. Very hard to hold offset down
since the low Z at this node (does not play well) with the passive method.
The input diamond beta be the major factor. I have always chosen a high Z positive op-amp
servo to tweak the input diamond DC bias by (as little as a few microvolts) to tweak the offset.
(below) tried this with a tested cfa one (built and ran). It seems to be the (only)
way for this type amp stage - my new one will use this. THD is still single digit
PPM with the positive FB servo.
OS
